pin digital_read
simonc8
pin digital_read
Post by simonc8 » Wed Dec 04, 2019 10:18 am
I am trying to programme a HC-SR04 ultrasonic sensor mounted on a 4tronix bitbot robot. The following micropython code is from the 4tronix website:
from microbit import *
from utime import ticks_us, sleep_us
SONAR = pin15
def sonar( ):
    SONAR.write_digital(0) # Clear trigger
    sleep_us(2)
    SONAR.write_digital(1) # Send 10us Ping pulse
    sleep_us(10)
    # set pin15 to read, with no voltage applied
    SONAR.set_pull(SONAR.NO_PULL)
    while SONAR.read_digital() == 0: # ensure Ping pulse has cleared
        pass
    start = ticks_us() # define starting time
    while SONAR.read_digital() == 1: # wait for Echo pulse to return
        pass
    end = ticks_us() # define ending time
    echo = end - start
    distance = int(0.01715 * echo) # Calculate cm distance
    return distance
    display.scroll(sonar())
    sleep(1000)
but this doesn't work, because it gets stuck at the line
If I programme the microbit using PXT the sensor works properly. PXT uses the c++ function pulseIN() to read the digital pin but I can't find a way to get micropython to mimic the same behaviour.
Grateful for assistance.
lujo
Re: pin digital_read
Post by lujo » Fri Dec 06, 2019 8:31 am
Did you really used the same pin for triggering and reading back the echo?
If I use two different micro:bit pins, it works. Using your code to start with:
from utime import ticks_us, sleep_us, ticks_diff
def sonar( ):
    pin0.write_digital(0)
    sleep_us(10)
    pin0.write_digital(1)
    sleep_us(10)
    while pin1.read_digital() == 0:
        pass
    start = ticks_us()
    while pin1.read_digital() == 1:
        pass
    end = ticks_us()
    cm = ticks_diff(end, start) // 58
    return cm
    sleep(1000)
lujo
simonc8
Post by simonc8 » Fri Dec 06, 2019 10:25 am
Thanks for your reply.
I have no control over the pins, as that's the way the bitbot is wired up.
I know it works using the same pin for both because this code in Java PXT returns the distance (albeit not very accurately):
basic.forever(function () {
    basic.showNumber(Math.round(bitbot.sonar(BBPingUnit.Centimeters)))
    basic.pause(1000)
the bitbot PXT library function sonar I assume comes from the github project at
https://github.com/srs/pxt-bitbot
and the code in main.ts includes:
    export function sonar(unit: BBPingUnit): number {
        // send pulse
        let trig = DigitalPin.P15;
        let echo = DigitalPin.P15;
        let maxCmDistance = 500;
        pins.setPull(trig, PinPullMode.PullNone);
        pins.digitalWritePin(trig, 0);
        control.waitMicros(2);
        pins.digitalWritePin(trig, 1);
        control.waitMicros(10);
        // read pulse
        let d = pins.pulseIn(echo, PulseValue.High, maxCmDistance * 58);
        switch (unit) {
            case BBPingUnit.Centimeters: return d / 58;
            case BBPingUnit.Inches: return d / 148;
            default: return d;
This uses the function pulseIn() for the sensing but I can't find the source for this function to see exactly what it does to try and duplicate it in micropython.
lujo
Post by lujo » Sat Dec 07, 2019 1:44 am
There is a pulse in function. Source is here: https://github.com/bbcmicrobit/micropyt ... ne_pulse.c
from utime import sleep_us
from machine import time_pulse_us
def sonar( ):
    sleep_us(10)
    sleep_us(10)
    pin1.set_pull(pin1.PULL_DOWN)
    t = time_pulse_us(pin1, 1, 10**5)   # pin, level, time-out
    return t // 58
    sleep(1000)
lujo
Post by jimmo » Sat Dec 07, 2019 11:12 am
Can confirm that lujo's code works on the bit:bot -- here's code that I've seen working (which is basically identical to lujo's snippet above). https://github.com/jimmo/microbit-demos ... -finder.py
simonc8
Post by simonc8 » Tue Dec 10, 2019 7:01 pm
Thanks for the replies. I loaded lugo's code onto the bitbot and it just returns -1 all the time, which means it's timing out while waiting for the pulse to finish. Not quite sure what this means.
I would suspect the batteries except for the fact that the same bitbot will return ultrasonic distances ok when programmed with PXT blocks in microsoft.makecode.org.
Mysterious.
Post by jimmo » Wed Dec 11, 2019 2:58 am
I went looking through my notes from a summer school I used to teach at -- https://github.com/jimmo/ncss-embedded/ ... opixels.md This is specifically about using the bit:bot with the micro:bit and MicroPython.
There's a code snippet at the end:
def distance_cm():
  # Send a pulse on pin 15
  pin15.write_digital(1)
  pin15.write_digital(0)
  # Read from the pin to turn it back to an input.
  pin15.read_digital()
  # Turn on the internal pull-up resistor
  pin15.set_pull(pin15.PULL_UP)
  pulse_time = machine.time_pulse_us(pin15, 1)
  if pulse_time < 0:
    return 0
  return pulse_time * 0.034 / 2
  print(distance_cm())
  sleep(500)
simonc8
Post by simonc8 » Wed Dec 11, 2019 9:57 am
jimmo - brilliant - that code works!
Many thanks for your help. Your notes on the bit:bot are extremely useful as well.
On your github pages for ncss-embedded is there something I need to have installed so the equations show properly? In my browser they just show as the text eg
\begin{equation} V_{tot} = \frac{V}{2} \end{equation}
Post by jimmo » Tue Dec 17, 2019 1:46 am
I originally wrote all the formulae using Math URL (see the note in the main readme file) but a friend wanted to make it into a PDF so he set it up to use pandoc and LaTeX etc, so that's why the equations look like that. Here's a copy of the generated PDF https://drive.google.com/file/d/0B-O86M ... sp=sharing
simonc8
Post by simonc8 » Tue Dec 17, 2019 5:06 pm
Many thanks - that is a really useful document.
