Radio not working
pmulvey
Radio not working
Post by pmulvey » Sat May 09, 2020 9:33 pm
I set up a Master / Slave arrangement using Makecode plus a small bit of Javascript, it works great. I then started to rewrite the Master in Micropython and the Slave receives no signal. I even tried looping through all of the channels but no joy. Before I get into details is there anything blindingly obvious that I may be overlooking? Is there anything in the micropython radio implimentation that might be incoompatible with the blocks?
Paul Mulvey
pmulvey
Re: Radio not working
Post by pmulvey » Sun May 10, 2020 9:14 am
Thanks lujo,
I had read about the complex packet issue before and forgot about it! I followed your link and at your advice I used Phil Hall's implementation. All seems good now for transmit and receive packets.
Paul Mulvey
