joshuachu3
Post by joshuachu3 » Fri Jul 17, 2020 6:18 am
I'm trying to import Pin from machine but get the error cannot import name Pin. I am trying to write a event handler for when there is a rising edge, is there any other way to do this?
lujo
Re: from machine import Pin
Post by lujo » Fri Jul 17, 2020 7:08 am
MicroPython v1.9.2-34-gd64154c73 on 2017-09-01; micro:bit v1.0.1 with nRF51822
>>> import microbit
>>> [p for p in dir(microbit) if p.startswith('pin')]
['pin0', 'pin1', 'pin2', 'pin3', 'pin4', 'pin5', 'pin6', 'pin7', 'pin8', 'pin9', 'pin10', 'pin11', 'pin12', 'pin13', 'pin14', 'pin15', 'pin16', 'pin19', 'pin20']
Post by deshipu » Fri Jul 17, 2020 10:59 am
Hi @joshuachu3. The MicroPython on Micro:bit is different than MicroPython on all other platforms, and the examples you find for other platforms will not work on it. In particular, there are no advanced functions such as pin interrupts. I hope that helps.
Post by jimmo » Mon Jul 20, 2020 4:40 am
On the micro:bit port, the Pin class is in the "microbit" module instead, and as lujo has pointed out, rather than constructing them, there's a predefined set of pre-initialised pin instances. As deshipu said, the micro:bit port is a bit different -- partly for simplification, and partly because it predates a lot of the work to standardise the hardware APIs across ports.
There's no direct way to do this, but depending on your use case, there is at least a way to time pulses via https://microbit-micropython.readthedoc ... e_pulse_us (and the pin object you can pass to this is any of the pinN instances from the microbit module).
But unfortunately, no easy way to write a generic low-latency edge detection (other than polling).
