Microbit DAPlink or Computer or USB drive problem?
Posted: Mon Nov 02, 2020 4:35 am
my microbit code:
Problem:
In my computer :
It worked all day, The yellow light behind the board also blinks.There is no problem.
But it's on my friend's computer:
Can only work normally for a few minutes or ten minutes,Time is not fixed. The yellow light behind the board is usually on, not flashing,My friend's computer can't get data via USB. Then I change the board back to my computer ,it was able to work a full day. Why? I've been searching for a week and I can't find the reason. Do you have this problem? What do you think is most likely the problem?
while(1)
microbit.serial.send(microbit.thermometer.getTemperature());
microbit.sleep(50); //Send the temperature to the computer every 50ms
In my computer :
