Connecting external grove button to Microbit
amberxoxo
Post by amberxoxo » Thu Nov 19, 2020 2:40 am
Hi! Can someone please help me - I'm trying to connect an external grove button to the microbit. How can I code it in python to get it to work so that when you press it once, the neopixels glow a white light and then if you press it again it turns off? Thanks
Re: Connecting external grove button to Microbit
Post by jimmo » Thu Nov 19, 2020 10:45 pm
The simplest way to do this is if you're not also using the onboard "A" and "B" buttons, then if you connect it to pins 5 or 11, then you can make the external button behave as A or B. See the pinout here:
https://os.mbed.com/platforms/Microbit/
Then in Python you can use button_a.was_pressed() etc.
Otherwise, you can use any pin and access it as a digital pin. pinN.read_digital() to read the current state of the pin. Ideally what you do is in a loop you record the current value of the pin and detect a change from 0 to 1.
neopixels_on = False
last_state = 0
  new_state = pinN.read_digital()
  if new_state == 1 and last_state == 0:
    if neopixels_on:
      # Turn them off
      # Turn them on
      neopixels_on = True
  last_state = new_state
This will use an internal pull-down resistor, but you might need to change it to pull-up depending on the way the grove module works. https://microbit-micropython.readthedoc ... 1/pin.html
