Maqueenplus
Posted: Sat Dec 12, 2020 1:25 pm
by Jackpo
Hallo.
How can i program de robot Maqueenplus. I can not find a schematic from this bot so i don't have pin-numbers how to program the motors.
Thanks.
Jack.
Re: Maqueenplus
Posted: Sun Dec 13, 2020 11:39 pm
by lujo
Check out:
https://www.dfrobot.com/forum/viewtopic ... 176#p42615
That did not help me: downloads mu-editor with maqueen library distributed
as MS-Windows installer file. No MS-Windows here.
So, figured it out by sending bytes to i2c addr, see what happens.
Here is my line-following program for the mu-editor.
$ cat maqueen_line_following.py
from microbit import i2c, display, button_a, button_b, sleep
from microbit import pin13 as ir_left_led, pin14 as ir_right_led
from microbit import accelerometer
from micropython import const
i2c.init()
i2c_addr = const(16)
speed = const(50)
def drive():
i2c.write(i2c_addr, bytes((0,0,speed)))
i2c.write(i2c_addr, bytes((2,0,speed)))
def turn_right():
i2c.write(i2c_addr, bytes((0,0,speed*2)))
i2c.write(i2c_addr, bytes((2,0,0)))
def turn_left():
i2c.write(i2c_addr, bytes((0,0,0)))
i2c.write(i2c_addr, bytes((2,0,speed*2)))
def stop():
def run():
p = 0
if accelerometer.is_gesture('face up'):
stop()
i = ir_left_led.read_digital() + 2 * ir_right_led.read_digital()
if i == 0:
drive()
elif i == 1:
turn_right()
p = i
elif i == 2:
turn_left()
p = i
if p == 1:
turn_right()
if p == 2:
turn_left()
run()
lujo
Re: Maqueenplus
Posted: Mon Dec 14, 2020 10:39 am
by Jackpo
Hallo Iujo
Thanks for answer, but the line: Check out:
gives: can not find!
What is wrong?
Thanks.
Jack.
Re: Maqueenplus
Posted: Mon Dec 14, 2020 12:27 pm
by lujo
Try this: go to
https://www.dfrobot.com/forum/viewforum.php?f=7 (the Products
forum) and click Robotics. Search for micropython, read the post by nana.wang.
lujo
Re: Maqueenplus
Posted: Wed Dec 16, 2020 1:26 pm
by Jackpo
Hallo Lujo'
Sorry, but the linefollower program i tried but does not not work.
Jack.
