I am a regular user of PyCharm which is my preferred IDE so have tried to setup micropython focusing on micro:bit using PyCharm.
My preferred environment manager is Anaconda using which I have set-up python 3.6 environment (as I believe this is currently what microphython uses/based on) I've been following this https://mryslab.github.io/pseudo-microbit/ tutorial installing pseudo-microbit via
pip
conda
I've experienced several issues:
1) on my mac
site-packages/microbit/
images.py
2) I have defined uflash as an external tool, within PyCharm. PyCharm seems quite happy and doesn't report errors when flashing. However the micro:bit seems to get partially programmed and then reports with an unhappy face!
All wise/random thoughts gratefully accepted.
