Hi experts,
Its any pin-map available in nodeMCU ESP32 module on micropython?
Regards
Pin map on NodeMCU ESP32 module
Re: Pin map on NodeMCU ESP32 module
Do you mean like http://circuitpython.readthedocs.io/en/ ... nit__.html
Do you want to know what values a machine.Pin constructor will take, or what named functions the pins have? Something else? What does pin map mean to you?
Typically the boards have numbers printed on the connections like Gxx. You can assume that xx is the Pin number used in the machin.Pin() constructor.
For example, in ESP8266 board, if I use nodeMCU module, below map list can help me to locale relationship between micropython and nodeMCU:
A0---------------ACD0
D1---------------GPIO5
D2---------------GPIO4
D3---------------GPIO0-------FLASH
D4---------------GPIO2-------TX0D1
D5---------------GPIO14------HSPICLK
D6---------------GPIO12------HSPIO
D7---------------GPIO13------RXD2----HSPID
D8----------------GPIO15-----TXD2----HSPICS
D9---------------GPIO3--------RXD0
D10--------------GPIO1--------TXD0
I drive 595 chip chains via SPI and they were connected on GPIO14, 12 and 13.
but in ESP32, i can't find the mapping information likes that. I mean, is ESP32 has map list likes ESP8266?
I googled ESP32 pinout and found this...
I tend to use graphical pinouts like this, looking for the GPIOxx identifier where xx is the number you would use in the machine.Pin() constructor. Any good?
GREATTTTTTTTTTT!!! Thanks a lot!!!!!!!
