I am trying to add functions to an existing module. I am not an experienced coder so please be gentle. I am trying to learn.
The module is about the ESP32-CAM support. I want to add a flip function. The module is already working. I just want to add functions to it. I manage to call the function that I added using:
import camera
camera.flip()
But it always returns "Flipping Failed". What am I doing wrong? I tried to look at the Arduino CameraWebServer example because all the other functions used in the camera module look similair to the Arduino example.
The files used:
https://github.com/Lennyz1988/micropyth ... odcamera.c
https://github.com/Lennyz1988/esp32-cam ... e/sensor.h
https://github.com/Lennyz1988/esp32-cam ... p_camera.h
Arduino example:
sensor_t * s = esp_camera_sensor_get();
//initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1);//flip it back
s->set_brightness(s, 1);//up the blightness just a bit
s->set_saturation(s, -2);//lower the saturation
//drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
In the file sensors.h is the function I want to add.
sensors.h
typedef struct _sensor sensor_t;
typedef struct _sensor {
sensor_id_t id; // Sensor ID.
uint8_t slv_addr; // Sensor I2C slave address.
pixformat_t pixformat;
camera_status_t status;
int xclk_freq_hz;
// Sensor function pointers
int (*init_status) (sensor_t *sensor);
int (*reset) (sensor_t *sensor);
int (*set_pixformat) (sensor_t *sensor, pixformat_t pixformat);
int (*set_framesize) (sensor_t *sensor, framesize_t framesize);
int (*set_contrast) (sensor_t *sensor, int level);
int (*set_brightness) (sensor_t *sensor, int level);
int (*set_saturation) (sensor_t *sensor, int level);
int (*set_gainceiling) (sensor_t *sensor, gainceiling_t gainceiling);
int (*set_quality) (sensor_t *sensor, int quality);
int (*set_colorbar) (sensor_t *sensor, int enable);
int (*set_whitebal) (sensor_t *sensor, int enable);
int (*set_gain_ctrl) (sensor_t *sensor, int enable);
int (*set_exposure_ctrl) (sensor_t *sensor, int enable);
int (*set_hmirror) (sensor_t *sensor, int enable);
int (*set_vflip) (sensor_t *sensor, int enable);
int (*set_aec2) (sensor_t *sensor, int enable);
int (*set_awb_gain) (sensor_t *sensor, int enable);
int (*set_agc_gain) (sensor_t *sensor, int gain);
int (*set_aec_value) (sensor_t *sensor, int gain);
int (*set_special_effect) (sensor_t *sensor, int effect);
int (*set_wb_mode) (sensor_t *sensor, int mode);
int (*set_ae_level) (sensor_t *sensor, int level);
int (*set_dcw) (sensor_t *sensor, int enable);
int (*set_bpc) (sensor_t *sensor, int enable);
int (*set_wpc) (sensor_t *sensor, int enable);
int (*set_raw_gma) (sensor_t *sensor, int enable);
int (*set_lenc) (sensor_t *sensor, int enable);
} sensor_t;
* @brief Get a pointer to the image sensor control structure
* @return pointer to the sensor
sensor_t * esp_camera_sensor_get();
STATIC mp_obj_t camera_flip(){
if (!s) {
ESP_LOGE(TAG, "Flipping Failed");
return mp_const_false;
s->set_vflip(s, 1);
return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_0(camera_flip_obj, camera_flip);
STATIC const mp_rom_map_elem_t camera_module_globals_table[] = {
{ MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_camera) },
{ MP_ROM_QSTR(MP_QSTR_flip), MP_ROM_PTR(&camera_flip_obj) },
