main.py does not appear to working after boot
rpr
Re: main.py does not appear to working after boot
Post by rpr » Wed Jul 17, 2019 3:48 pm
Can you try a simple boot.py and main.py?
Edit to add: Can you use the
 code
block so that it can be easier to see the indentation?
Post by pythoncoder » Thu Jul 18, 2019 5:13 am
The usual way to program MicroPython devices is as follows.
  • Make no changes to boot.py (or absolutely minimal config changes).
  • main.py consists of a single statement: import my_module
my_module.py contains your code. That way you can develop your code at the REPL with an empty main.py. When it's working, adapt main.py to do the import.
I suggest you try that approach. Running significan amounts of code in boot.py is not recommended because it runs very early in the boot process.
smith.randallscott
Post by smith.randallscott » Thu Jul 18, 2019 10:20 am
@pythoncoder Thank you I will try that
smith.randallscott
Post by smith.randallscott » Thu Jul 18, 2019 6:35 pm
@pythoncoder There must be something wrong with the way I main creating main.py. I created my_module.py and called it from main.py; and it would work if issued a soft reboot (cntr+d) from the REPL. However, it would not work if I power cycled the board.
If however; with main.py deleted from the file system, I called my_module.py from boot.py all works as expected.
Can anyone explain this?
Post by Roberthh » Thu Jul 18, 2019 7:06 pm
Looking at you main.py and boot.py, it it quite a bit of code. Of the things I find surprising:
- the functions wifi_connect() is defined in boot.py, but called in main.py
- you import MQTT lib in boot.py and define client there, but call client.connect in main.py
- same with onewire, ds1820, main_running_led, and so on.
I would never do that, because it is not that boot.py imports main.py. They just happen to run in the same name space. If you import main.py (or my_module.py) from boot.py, the relation is more obvious, and things are guaranteed to work. That still does not explain why it works at Ctrl-D, and not on power on.
Also: You tell that main.py is running by the blinking LED in the main loop of main.py. But until then a lot could have failed. For the test like yours, I would add a LED loop at the very beginning of main.py, including the redefinition of the Pin object. Thus you can be sure that all you need for the test is locally present.
P.S.: The roles of boot.py and main.py are not clearly distinct. You can leave boot.py (almost) empty and put everything in main.py, or, like @pythoncoder suggested, let main.py only import your service code.
smith.randallscott
Post by smith.randallscott » Thu Jul 18, 2019 7:39 pm
@Roberthh The current operating code is a follows
boot.py
import my_module
my_module.py
from time import sleep
def led_state():
	print(diag_led())
print('my_module loaded')
diag_led = Pin(25, Pin.OUT)
diag_led.on()
watch_dog_counter = 0
watch_dog_count_up = True
sleep(3)
diag_led.off()
I originally had the import statement in main.py, but it didn't work, so I moved it to boot.py, and it worked. I still don't understand why.
Post by Roberthh » Thu Jul 18, 2019 7:50 pm
That's indeed very strange. Can you try another ESP32 board?
smith.randallscott
Post by smith.randallscott » Thu Jul 18, 2019 8:05 pm
Not right now, but hopefully in the near future.
