asynycio as_GPS
Re: asynycio as_GPS
Post by pythoncoder » Wed Jan 15, 2020 7:17 am
Yes. The main part of the code should read
    with open(fn, 'w') as f:
        f.write(str_start)
                f.write(gps.longitude_string(as_GPS.KML))
                f.write(',')
                f.write(gps.latitude_string(as_GPS.KML))
                f.write(',')
                f.write(str(gps.altitude))
                f.write('\r\n')
                led(off)
                # for _ in range(interval * 10):
                await asyncio.sleep_ms(100)
            except KeyboardInterrupt:
                break
        f.write(str_end)
I can see no reason why this wouldn't work, but having no Pycom hardware I can't test it.
Using a keyboard interrupt to break does ensure that str_end is written but runs the risk that the last record will be incomplete. My version polls a switch to avoid this risk, with the switch only being checked after the record has been written.
romeotango
Re: asynycio as_GPS
Post by romeotango » Thu Jan 16, 2020 11:51 am
The keyboardInterrupt is intended as a temporary solution for evaluation
Write errors on the SD card are over. I formatted the card again in LoPy, obviously there was a discrepancy in access between micropython and ftp. So done. Thank You for your patience.
Overall I like the callback function very much. I think it is the best way to read the stream from the GPS continuously.
But the callback does not work for me.
import gc
gc.collect()
import as_GPS
gc.collect()
import uasyncio as asyncio
gc.collect()
gc.threshold(gc.mem_free() // 4 + gc.mem_alloc())
def callback(gps, *_):  # Runs for each valid fix
    print("cb", gps.latitude(), gps.longitude(), gps.altitude)
async def test():
    print('waiting for GPS data')
    await gps.data_received(position=True, altitude=True)
    print ("Data received")
    print(gps.latitude(), gps.longitude(), gps.altitude)
    await asyncio.sleep(60)  # Run for one minute
uart= UART(1, baudrate=9600, pins=('P20','P21'))
print (uart.readline())
sreader = asyncio.StreamReader(uart)  # Create a StreamReader
gps = as_GPS.AS_GPS(sreader, fix_cb=callback)  # Instantiate GPS
print (gc.mem_free())
print (gc.mem_alloc())
loop.run_until_complete(test())
comment
None from print (uart.readline())
None dto
10176 memfree
56832 memallocate
Data received
[52.12479, 'N'] [8.638245, 'E'] 98.9
last debug print shows valid sentence
The callback is not executed here.
Maybe the data set from my GPS is not sufficient to fulfill the condition?
Support is still very welcome. :geek:
Line 224 in as_GPS.py
if isinstance(s_type, int) and (s_type & self.cb_mask):
                # Successfully parsed, data was valid and mask matches sentence type
                self._fix_cb(self, s_type, *self._fix_cb_args)  # Run the callback
Re: asynycio as_GPS
Post by pythoncoder » Thu Jan 16, 2020 5:04 pm
I'm baffled. Your code works fine here on a Pyboard D. My only adaptations were a) to turn on the 3.3V line and b) to specify the UART - i.e. remove the pin identifiers.
romeotango
Re: asynycio as_GPS
Post by romeotango » Thu Jan 16, 2020 6:39 pm
Probably that is because it is your code from the tutorial :P
And your fast_io Version.
Will try the other uasyncio's ...
Re: asynycio as_GPS
Post by pythoncoder » Fri Jan 17, 2020 7:52 am
Well I recognised the code, that was why I was astonished it wouldn't run. I ran it against official uasyncio V2, not my version.
I suggest you stick with official uasyncio V2 to remove one variable from the setup. Presumably this is what Pycom support? In general V2 works so long as you don't get involved with issues like fast I/O and task cancellation. None of your code samples will challenge that version in any way.
If callbacks aren't taking place in such a simple code sample I'm feeling rather suspicious about Pycom firmware.
romeotango
Re: asynycio as_GPS
Post by romeotango » Sun Jan 19, 2020 7:40 pm
I can't think of a reason for this, but I think that somehow this if statement
does not return True and therefore the callback is not called.
I tried again today with another GPS receiver, but the result was without success. Somehow I can't imagine that it is related to the micropython from Pycom, but this is just a feeling ;)
OK, next step.
Thanks to the hints of MostlyHarmless, I have now set up everything to compile frozen bytecode. I use the toolchain from Pycom for this. After having somehow bricked a Linux under virtualbox with all the $PATH changes, I went back to the docker container. And that's how it worked. :)
So it goes on and on...
Thanks for the support and have a nice week
Rainer
Re: asynycio as_GPS
Post by pythoncoder » Mon Jan 20, 2020 9:17 am
My guess is still that the problem was in firmware. When you recompiled to implement frozen bytecode you doubtless used the latest sources and very likely acquired a bugfix.
Freezing bytecode helps greatly with RAM shortages, but it's not magic. It won't repair broken code ;) So the only thing left is the rebuild.
