Hello!
1) Firmware built with ESP-IDF v3.x, with support for BLE, LAN and PPP
The description for ESP-IDF v3.x indicates BLE support, but I can’t find something to use it. How to do it?
2) GENERIC : esp32-idf3-20200414-v1.12-368-gbd63c26dd.bin
Installed the latest firmware and esp32 is constantly rebooted. is that so?
With esp32-idf3-20191220-v1.12.bin does not reboot.
Board: ESP32 Lolin32
bluetooth ESP-IDF v3.x
Re: bluetooth ESP-IDF v3.x
http://docs.micropython.org/en/latest/l ... tooth.html
and examples at
https://github.com/micropython/micropyt ... /bluetooth
That's surprising... which ESP32 board/module do you have? Do you see the same issue with the IDF4 version? When does it reboot? Did you erase flash first?
The 1.12 stable release (i.e. esp32-*-20191220-v1.12.bin) only supports BLE in the IDF 4.0 version (at the time of the 1.12 release, Espressif hadn't added NimBLE support to IDF 3.3).
However, the nightly builds support BLE in both 3.3 and 4.0.
How confusing they are with BLE.
p.s.
Sorry, forgot to indicate the board.
ESP32 lolin32
esp32-idf4-20200415-v1.12-371-gf534b9976.bin - work it!
new firmware esp32-idf3-20200415-v1.12-371-gf534b9976.bin - does not work (constantly reboot).
I use ESP32 download tools v3.6.8. Erase flash, then download the firmware at 0x1000.
p.s.
ESP32 lolin32
I just ran a couple checks on IDF3 and IDF4 builds for the TinyPico builds.
I confirmed the ubluetooth module is only in nightly IDF3 builds as Jimmo stated.
The website says IDF4 doesn't support WLAN. Is that out of date or does it not _fully_ support WLAN, because I was able to connect and get an IP Address with IDF4 builds.
IDF3 1.12 Stable on 2020-03-16
ubluetooth module is NOT included
IDF3 1.12 Nightly Build 451 on 2020-05-13
ubluetooth module IS included
IDF4 1.12 Stable on 2020-03-16
network IS included
wlan.connect() worked... Despite the notes on the site saying it does not.
IDF4 1.12 Nightly Build 451 on 2020-05-13
network IS included
os.uname() == (
sysname='esp32', nodename='esp32', release='1.12.0',
version='v1.12 on 2020-03-16', machine='TinyPICO with ESP32-PICO-D4'
os.uname() == (
version='v1.12-451-g18fb5b443 on 2020-05-13',
os.uname() == (
network IS included
os.uname() == (
network IS included
One last comment... On the IDF3 and IDF4 nightly builds I was able to do a simple gap_scan and see the data. On the IDF4 stable build there are a few odd things that are fixed in the nightly build (no mac address, complaints about ble.active(True) before doing a scan are two) but as I said these go away in both night builds.
So, on May 13, 2020, if you're looking at BLE.. You gotta go to the nightly builds.
