Thanks, really would like to test drive one of those Pyboard D. Just that it is no available on our local Element14 or RS.pythoncoder wrote: ↑Mon Jun 01, 2020 7:19 am@tve I have no desire to "bash" the ESP32. A Ford Fiesta and a Porsche 911 both have merits. I happen to own the formerSo I see the importance of low cost and recognise the great work you and others have done on the ESP port. But I also recognise professional quality hardware when I see it.
It is a fact that the interrupt latency of an ESP32 is much worse than a Pyboard D, especially as it doesn't support hard IRQ's. So we are talking several ms if an interrupt happens to occur while a GC is in progress. I gather that with SPIRAM, a GC can take over 100ms. A Pyboard responds to a hard IRQ in (IIRC) about 20μs. That is a huge difference.
Another issue is stability. As you know I've done a lot of work on resilient MQTT. The Pyboard D ran for six weeks without a restart, exchanging nearly 1,000,000 messages. The test would probably still be running if my wife hadn't accidentally pulled the plug to run Christmas lightsThe ESP32 can't get close, resetting every few days. Testing was done using the same code, in the same physical location and the same power supply.
To be fair the ESP32 has one killer feature for those of us who need fast signals: the awesome RMT interface. I'd love to see support for this fixed and extended.
For some users price trumps performance. Some applications don't care about ISR response and can handle occasional reboots, in which case a Pyboard would be overkill. I welcome diversity, but we should document and recognise these differences otherwise new users will be puzzled and disappointed.
The other reason for supporting Pyboards is that proceeds from their sale keep this whole show on the road. I think those who can afford them should consider buying them.
Stability of ESP32 vs ESP8266
Re: Stability of ESP32 vs ESP8266
You can get it from the Micropython Store: https://store.micropython.org/
- rcolistete
One super-microcontroller with STM32 is the Portenta H7, US$92 for default version, it started selling :kevinkk525 wrote: ↑Mon Jun 01, 2020 5:41 amThat's nice but are there some STM32 boards with Wifi too?
Also it's nice to buy a $4 STM32 but they got no additional SPI flash so they are limited to 256kB which means you need a very special and small firmware of MP to even work with those. Also they are 411 series with only 100MHz.
https://www.newark.com/arduino/abx00042 ... duino-2518
uhm thanks, I was more interested in something close to the esp32, not more expensive than the pyboard Drcolistete wrote: ↑Tue Jun 02, 2020 7:30 pmOne super-microcontroller with STM32 is the Portenta H7, US$92 for default version, it started selling :kevinkk525 wrote: ↑Mon Jun 01, 2020 5:41 amThat's nice but are there some STM32 boards with Wifi too?
Kevin Köck
- rcolistete
After being introduced to Portenta H7 you can now see the Pyboard D (even SF6W) as a cheap microcontroller...kevinkk525 wrote: ↑Tue Jun 02, 2020 8:59 pmuhm thanks, I was more interested in something close to the esp32, not more expensive than the pyboard D![]()
Just wanted to add my experience to the pot.
I have an ESP-32 hooked up to a device and it is also connected via MQTT. Sending messages every minute. Been flawless for almost a full year now. It communicates via modbus RTU over TTL (with a driver I modified to work) too. ESP-32 seem to be decent. I also have esp32's in a ton of other locations and facilities and have had very good success with them. I've never used a pyboard but the esp8266's I have used were a little more inconsistent with connectivity and a couple just died. Probably not the case with all 8266's. Never used pyboard but sounds really nice.
Hope this helps someone.
Thank you,
Thank you,
