ESP32 machine.PWM
marestudio2004
Re: ESP32 machine.PWM
Post by marestudio2004 » Sun Dec 19, 2021 10:30 pm
I have esp32, what is solution?
Post by Roberthh » Mon Dec 20, 2021 6:44 am
Try to use the daily build: https://micropython.org/resources/firmw ... 2ebe09.bin.
See the web page for upload instructions: https://micropython.org/download/esp32/
marestudio2004
Post by marestudio2004 » Mon Dec 20, 2021 7:49 am
Thanks a lot!
I'll try and report my impressions!
marestudio2004
Post by marestudio2004 » Mon Dec 20, 2021 12:15 pm
Sorry, it doesn't seem to be a mistake in the firmware and timing!
Is pwm.deinit () automatically sent commands to return the servo to the starting position and is it possible to change it?
This is my code for servo motor control:
'''klapna'''
class klapna:
def __init__(self, pozicija):
self.pozicija = pozicija
p2 = machine.Pin(32)
servo = machine.PWM(p2,freq = 50)
servo.duty(pozicija)
servo.deinit() # After servo.deinit() esp32 send min value of 95 every time
klapna(pozicija=130) # 95 - 130 min-max
marestudio2004
Post by marestudio2004 » Mon Dec 20, 2021 1:18 pm
I just tried this code on the MicroPython v1.16 on 2021-06-23; ESP32 module with ESP32, and everithing work!
That it is not a mistake in the version v1.17...?
Post by Roberthh » Mon Dec 20, 2021 2:12 pm
It may be that the deinit() method changed. Why do you call deinit()?
marestudio2004
Post by marestudio2004 » Mon Dec 20, 2021 5:03 pm
In case I don't use deinit (), it's as if there is some interference (signal) that moves the servo in small movements!
I am not an expert in the field of microcontrollers ... My field of expertise is acoustics and audio signal processing ...
Is there an error in the code given in the previous post?
Post by Roberthh » Mon Dec 20, 2021 5:06 pm
Is that constantly moving in one direction or moving forth and back?
Post by Roberthh » Mon Dec 20, 2021 5:15 pm
Which parameters do you use when this happens: freq, duty
Post by Roberthh » Mon Dec 20, 2021 5:28 pm
With respect to deinit(), I see no difference between v1.16 and v1.17. Both switch off the PWM signal.
