# Notes: the offset of the partition table itself is set in
# $IDF_PATH/components/partition_table/Kconfig.projbuild.
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 0xE00000,
vfs, data, fat, 0xE10000, 0x1F0000,
There are no error messages during building or flashing the firmware, but on Thonny IDE it is showing storage space of 1.9MB instead of 14Mb.
If I use the partition other than the one mentioned above it either gives the following error at boot
Performing initial setup
File "_boot.py", line 11, in <module>
File "inisetup.py", line 36, in setup
OSError: (-258, 'ESP_ERR_INVALID_ARG'
The filesystem appears to be corrupted. If you had important data there, you may want to make a flash snapshot to try to recover it. Otherwise, perform factory reprogramming of MicroPython firmware (completely erase flash, followed by firmware programming).
https://github.com/micropython/micropyt ... of-content
https://stackoverflow.com/questions/674 ... 2#69277852
Can you suggest to me what I am doing wrong? Why after increasing the Factory (App) partition, it is still showing 1.9Mb on Thonny?
