Hi, friends!
I would ask for a real life example/how to but I've just found it on GitHub: https://github.com/T-Wilko/MicroPython- ... /epaper.py
I look forward to see the driver for landscape orientation.
Thank you , T-Wilko!
Connecting LOLIN/WEMOS D32Pro V2.0 and 2.13 Inch e-paper
Re: Connecting LOLIN/WEMOS D32Pro V2.0 and 2.13 Inch e-paper
Hi!
I've created a landscape hack using a new framebuffer.
My work is also based on T-Wilko's IL3897-driver:
https://github.com/T-Wilko/MicroPython-IL3897-driver
Based on the example there:
Again, this is a hack, we spimply create a new framebuffer and just rotate and copy all pixels to this before displaying it. The code is not optimized for speed or memory usage, rotating and displaying takes maybe three seconds.
I have the LILYGO TTGO T5 V2.3 board btw, https://www.aliexpress.com/item/32869729970.html, and had to do some small changes to the epaper.py file to map the correct pins. If anyone else use this board, I've included the changes here.
import epaper
import framebuf
width = 256 # 250x122 pixels/bits, but need whole bytes for easy copy to the screen
height = 128
e = epaper.EPD()
e.init()
e.clearBuffer()
widebuf = bytearray(width*height // 8)
wf = framebuf.FrameBuffer(widebuf, width, height, framebuf.MONO_HLSB)
black = 0
white = 1
wf.fill(white)
wf.text("Hello wide WORLD!", 50, 100, black)
wf.line(0, 0, 249, 0, black)
wf.line(0, 0, 0, 121, black)
wf.line(0, 121, 249, 121, black)
wf.line(249, 121, 249, 0, black)
def displayRotatedBuffer():
global height, width, wf, e
TERMINATE_FRAME_READ_WRITE = const(0xFF) # not in datasheet, aka NOOP
BYTES_PER_LINE = 16
rotatebuf = bytearray(width*height // 8)
rf = framebuf.FrameBuffer(rotatebuf, height, width, framebuf.MONO_HLSB)
# Rotate the wide buffer 90 deg
for x in range(0, 122):
for y in range(0, 250):
rf.pixel(x, y, wf.pixel(250 - y, x))
e._command(b'\x24')
for x in range(0, BYTES_PER_LINE):
e._data(bytearray([rotatebuf[y * BYTES_PER_LINE + x]]))
e._command(b'\x22')
e._command(b'\xC7')
e._command(b'\x20')
e._command(bytearray([TERMINATE_FRAME_READ_WRITE]))
e.wait_until_idle()
class EPD:
def __init__(self):
self.spi = SPI(2, baudrate=20000000, polarity=0, phase=0, sck=Pin(18), mosi=Pin(23), miso=Pin(19))
self.spi.init()
dc = Pin(17)
cs = Pin(5)
rst = Pin(16)
Shorter and rotation both ways.
width = 250
height = 122
j_width = (width + 7) & 0xfff8 # Rounded up to next whole byte
j_height = (height + 7) & 0xfff8
widebuf = bytearray(j_width * height // 8)
wf = framebuf.FrameBuffer(widebuf, j_width, height, framebuf.MONO_HLSB)
def displayRotatedBuffer90():
global height, width, j_width, j_height, wf, e
rotatebuf = bytearray(j_height * width // 8)
rf = framebuf.FrameBuffer(rotatebuf, j_height, width, framebuf.MONO_HLSB)
for x in range(0, height):
for y in range(0, width):
rf.pixel(x, y, wf.pixel(width - y, x))
e.displayBuffer(rotatebuf)
def displayRotatedBuffer270():
# Rotate the wide buffer 270 deg
rf.pixel(height - x, y, wf.pixel(y, x))
