WT32-ETH01
Alex_III
WT32-ETH01
Post by Alex_III » Thu Mar 25, 2021 9:11 pm
WT32-ETH01 - ESP32 board with ethernet LAN8720
Price less than $ 10
I want to use it for home automation. Nobody tried it?
Alex_III
Re: WT32-ETH01
Post by Alex_III » Tue Apr 13, 2021 6:34 am
I tried it. Everything works fine.
The only problem is that almost all libraries Micropython are written for a wireless network, therefore, as a rule, they do not work on a wired LAN.
John12
Re: WT32-ETH01
Post by John12 » Tue Aug 10, 2021 2:49 pm
Hello Alex_III,
Did you try this example (i don't have a WT32-ETH01 to test it) :
https://github.com/emard/esp32lan8720 ?
296004848
Re: WT32-ETH01
Post by 296004848 » Sat Nov 27, 2021 3:22 pm
MicroPython v1.16 on 2021-07-22; ESP32 module with ESP32
>>> %Run -c $EDITOR_CONTENT
File "<stdin>", line 28, in <module>
OSError: esp_eth_driver_install failed
OSError: esp_eth_set_default_handlers failed (invalid parameter)
I tried this code, but there was a problem. Is there a solution?
