ESP32-CAM-MB + Development Board CH340G
Posted: Sat Mar 27, 2021 1:46 pm
I'm completely new to this and have recently found:
https://www.ebay.co.uk/itm/ESP32-CAM-MB ... 4204150016
which should be the same as:
https://www.amazon.com/Aideepen-ESP32-C ... 578LV?th=1
so I bought it and give it a try. Docs were clear enough and I tried flashing esp32-idf4-20210202-v1.14.bin (and some other images later), but even though flashing it was always successful according to output, I was not able to boot it at all.
Now after flashing it, I found online that one needs to hold the IO0 button (on the USB Programmer) pressed while powering or resetting the ESP32 board so I tried that in multiple combinations and variations, but I never got the prompt. Running $ picocom /dev/ttyUSB0 -b115200 makes it output "Terminal ready" and nothing after.
When I try to read something, I only get:
and note output gets trimmed here, I didn't remove anything.
alternatively I get nothing back or just something random:
Has anyone experience with this? Is it stuck in download mode?
Thanks,
Vedran
$ esptool.py --chip esp32 --port /dev/ttyUSB0 --before default_reset --after hard_reset erase_flash
esptool.py v3.0
Serial port /dev/ttyUSB0
Connecting.....
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 9c:9c:1f:c8:13:f4
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 3.1s
Hard resetting via RTS pin...
(in same cases here I removed the power and then plugged it again)
$ esptool.py --chip esp32 --port /dev/ttyUSB0 --baud 460800 write_flash --verify -z 0x1000 ./esp32-idf4-20210202-v1.14.bin
esptool.py v3.0
Connecting......
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Compressed 1567824 bytes to 982369...
Wrote 1567824 bytes (982369 compressed) at 0x00001000 in 22.0 seconds (effective 569.3 kbit/s)...
Hash of data verified.
Leaving...
Verifying just-written flash...
(This option is deprecated, flash contents are now always read back after flashing.)
Verifying 0x17ec50 (1567824) bytes @ 0x00001000 in flash against esp32-idf4-20210202-v1.14.bin
-- verify OK (digest matched)
$ jpnevulator --ascii --timing-print --tty /dev/ttyUSB0 --read
2021-03-26 23:12:36.138644:
65 74 73 20 4A 75 6E 20 20 38 20 32 30 31 36 20 ets Jun 8 2016
30 30 3A 32 32 3A 35 37 0D 0A 0D 0A 72 73 74 3A 00:22:57....rst:
30 78 31 20 28 50 4F 57 45 52 4F 4E 5F 52 45 53 0x1 (POWERON_RES
45 54 29 2C 62 6F 6F 74 3A 30 78 31 33 20 28 53 ET),boot:0x13 (S
2021-03-27 14:30:41.665467:
92 CD 28 36 5C 55 71 2B 71 70 D1 D0 E0 D2 65 5D ..(6\Uq+qp....e]
1B 6A 91 E9 F9 4A 3D 88 0A .j...J=..
Thanks,
Vedran
