"memory allocation failed" : possible to delete main.py ?
picpic020961
Post by picpic020961 » Fri Apr 02, 2021 6:41 am
Bonjour ,
with Thonny at boot my M5stack , this message with prompt:
>>> MemoryError: memory allocation failed, allocating 640 bytes
Is it possible to delete the boot.py ( or main.py ) ?
or erase_flash is the only solution ?
maybe binary save , edit/patch and reload ?
thanks for help
Regards
lbayo
Re: "memory allocation failed" : possible to delete main.py ?
Post by lbayo » Sat Apr 03, 2021 3:34 am
Hi and bonjour
I think it's a Thonny problem. Try exiting and entering Thonny again
marcidy
Post by marcidy » Sat Apr 03, 2021 5:36 am
if you can import,
>>> import os
>>> os.remove("main.py")
if you can't import anything, you probably can't use other tools either.
maybe try:
with open("main.py", 'w') as f:
    f.write("")
to overwrite it in place.
