Unable to perform a soft reset
br0kenpixel
Post by br0kenpixel » Sat Apr 03, 2021 6:01 pm
Hi. I'm trying out my ESP32 board and I noticed that the soft_reset function (in the machine module) does not work.
I have a boot.py file that looks like this:
print("Hello World!")
machine.soft_reset()
My ESP32 does not want to soft reboot. Basically, nothing happens. The "Hello World!" string is printed and that's it.
Hello World!
MicroPython v1.14 on 2021-02-02; ESP32 module (spiram) with ESP32
The function does work if I type it in manually into the REPL.
MPY: soft reboot
Hello World!
Could someone please explain why it's not working? I'm kinda confused. I'm using the official build from MicroPython's website (GENERIC_SPIRAM).
marcidy
Re: Unable to perform a soft reset
Post by marcidy » Sat Apr 03, 2021 6:39 pm
I assume you know this, but this is not really a good idea, you're going to end up in a boot loop you can't get out of without erasing the flash.
I'm curious why you'd want to do this, and specifically in boot.py rather than main.py?
That being said, looks like boot.py is handled slightly different from the repl and main.py, which isn't a complete answer to your question, but shines light on it.
machine.soft_reset() raises a SystemExit error, rather than executes the soft_reset. The soft_reset is in main.c.
ports/esp32/modmachine.c
STATIC mp_obj_t machine_soft_reset(void) {
    pyexec_system_exit = PYEXEC_FORCED_EXIT;
    mp_raise_type(&mp_type_SystemExit);
When done from main.py or the repl, it looks like it's checked which triggers the actual soft_reset. when executing boot.py, I don't think the particular error is checked / acted on.
ports/esp32/main.py:119-126
    pyexec_frozen_module("_boot.py");
    pyexec_file_if_exists("boot.py");
    if (pyexec_mode_kind == PYEXEC_MODE_FRIENDLY_REPL) {
        int ret = pyexec_file_if_exists("main.py");
        if (ret & PYEXEC_FORCED_EXIT) {
            goto soft_reset_exit;
notice how the return from pyexec_file_if_exists is not checked for boot.py, but is for main.py.
