Is it possible to disable ADC?
Is it possible to disable ADC function after use ADC to reduce power in sleep mode?
- OlivierLenoir
Re: Is it possible to disable ADC?
Did you try to deinit ADC and Pin?
or maybe this method:
pin_adc = Pin(32)
adc = ADC(pin_adc)
# your code
adc.deinit()
pin_adc.deinit()
adc = ADC(Pin(32))
# your code
adc.deinit()
Olivier Lenoir
https://gitlab.com/olivierlenoir
There is no deinit() method in ESP32's ADC now.
Finally I found a way to disable ADC by set registry 0x3FF4880C.
def disableADC():
mem32[0x3FF4880C] &= 0xFFF3FFFF
mem32[0x3FF4880C] |= 0x00020000
