ESP32 micropython Compilation error!!
xingkunpeng
Post by xingkunpeng » Wed Apr 14, 2021 3:34 am
CC extmod/mpexception.c
CC ../../lib/oofatfs/ff.c
CC ../../lib/oofatfs/ffunicode.c
CC ../../lib/littlefs/lfs2.c
CC ../../lib/littlefs/lfs2_util.c
CC ../../extmod/modbtree.c
In file included from ../../lib/berkeley-db-1.xx/PORT/include/../../btree/btree.h:44:0,
from ../../extmod/modbtree.c:38:
../../lib/berkeley-db-1.xx/PORT/include/mpool.h:50:2: error: expected specifier-qualifier-list before 'CIRCLEQ_ENTRY'
CIRCLEQ_ENTRY(_bkt) hq; /* hash queue */
../../lib/berkeley-db-1.xx/PORT/include/mpool.h:61:2: error: expected specifier-qualifier-list before 'CIRCLEQ_HEAD'
CIRCLEQ_HEAD(_lqh, _bkt) lqh; /* lru queue head */
../../extmod/modbtree.c:329:14: error: unknown type name 'FILEVTABLE'
STATIC const FILEVTABLE btree_stream_fvtable = {
../../extmod/modbtree.c:330:5: error: initialization makes integer from pointer without a cast [-Werror=int-conversion]
mp_stream_posix_read,
../../extmod/modbtree.c:330:5: note: (near initialization for 'btree_stream_fvtable')
../../extmod/modbtree.c:331:5: error: excess elements in scalar initializer [-Werror]
mp_stream_posix_write,
../../extmod/modbtree.c:331:5: note: (near initialization for 'btree_stream_fvtable')
../../extmod/modbtree.c:332:5: error: excess elements in scalar initializer [-Werror]
mp_stream_posix_lseek,
../../extmod/modbtree.c:332:5: note: (near initialization for 'btree_stream_fvtable')
../../extmod/modbtree.c:333:5: error: excess elements in scalar initializer [-Werror]
mp_stream_posix_fsync
../../extmod/modbtree.c:333:5: note: (near initialization for 'btree_stream_fvtable')
../../extmod/modbtree.c: In function 'mod_btree_open':
../../extmod/modbtree.c:362:52: error: passing argument 2 of '__bt_open' makes integer from pointer without a cast [-Werror=int-conversion]
DB *db = __bt_open(MP_OBJ_TO_PTR(pos_args[0]), &btree_stream_fvtable, &open
In file included from ../../extmod/modbtree.c:37:0:
../../lib/berkeley-db-1.xx/PORT/include/db.h:230:5: note: expected 'int' but argument is of type 'const int *'
DB *__bt_open __P((const char *, int, int, const BTREEINFO *, int));
../../extmod/modbtree.c:362:75: error: passing argument 3 of '__bt_open' makes integer from pointer without a cast [-Werror=int-conversion]
*db = __bt_open(MP_OBJ_TO_PTR(pos_args[0]), &btree_stream_fvtable, &openinfo,
../../lib/berkeley-db-1.xx/PORT/include/db.h:230:5: note: expected 'int' but argument is of type 'BTREEINFO * {aka struct <anonymous> *}'
../../extmod/modbtree.c:362:14: error: too few arguments to function '__bt_open'
../../lib/berkeley-db-1.xx/PORT/include/db.h:230:5: note: declared here
cc1: all warnings being treated as errors
../../py/mkrules.mk:63: recipe for target 'build-GENERIC_SPIRAM/extmod/modbtree.o' failed
make: *** [build-GENERIC_SPIRAM/extmod/modbtree.o] Error 1
micropytho Compilation error!
1 lib/berkeley-db-1.xx library file I have loaded and updated.
![image](https://user-images.githubusercontent.c ... d77112.png)
2 The following commands have been executed:
xkp@xkp-VirtualBox:~/esp32/micropython$ git submodule init lib/berkeley-db-1.xx
xkp@xkp-VirtualBox:~/esp32/micropython$ git submodule update
子模组路径 'lib/berkeley-db-1.xx':检出 '7b31cae3c0892a7fca2089cb0354a4920c98c413'
The result is still not good!
Hope to get your reply!
Best wishes!
marcidy
Re: ESP32 micropython Compilation error!!
Post by marcidy » Wed Apr 14, 2021 4:27 am
did you run make clean?
What commit are you using for micropython?
xingkunpeng
Post by xingkunpeng » Wed Apr 14, 2021 5:07 am
me:yes,i did。
me:Sorry, I'm not sure what you mean.
I'm compiling the micropython firmware for esp32 。
xingkunpeng
Post by xingkunpeng » Wed Apr 14, 2021 6:01 am
The log:
xkp@xkp-VirtualBox:/esp32/micropython/ports/esp32$ make clean
MicroPython v1.13-30-g1d344f446-dirty
Building with ESP IDF v4
rm -rf build-GENERIC_SPIRAM
GEN build-GENERIC_SPIRAM/sdkconfig.h
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/bootloader/subproject/main/
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/bootloader_support/src/
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/bootloader_support/src/esp32/
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/log/
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/soc/esp32/
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/soc/src/
mkdir -p build-GENERIC_SPIRAM/bootloader//home/xkp/esp32/esp-idf/components/spi_flash/
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_clock.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_common.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_flash.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_flash_config.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_init.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_random.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/bootloader_utility.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/flash_qio_mode.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/esp_image_format.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/flash_encrypt.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/flash_partitions.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/esp32/bootloader_sha.c
CC /home/xkp/esp32/esp-idf/components/bootloader_support/src/esp32/secure_boot.c
AR build-GENERIC_SPIRAM/bootloader/libbootloader_support.a
CC /home/xkp/esp32/esp-idf/components/log/log.c
AR build-GENERIC_SPIRAM/bootloader/liblog.a
CC /home/xkp/esp32/esp-idf/components/spi_flash/spi_flash_rom_patch.c
AR build-GENERIC_SPIRAM/bootloader/libspi_flash.a
CC /home/xkp/esp32/esp-idf/components/soc/esp32/cpu_util.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/gpio_periph.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_clk.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_clk_init.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_init.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_periph.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_pm.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_sleep.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_time.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/rtc_wdt.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/sdio_slave_periph.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/sdmmc_periph.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/soc_memory_layout.c
CC /home/xkp/esp32/esp-idf/components/soc/esp32/spi_periph.c
CC /home/xkp/esp32/esp-idf/components/soc/src/memory_layout_utils.c
AR build-GENERIC_SPIRAM/bootloader/libsoc.a
CC /home/xkp/esp32/esp-idf/components/bootloader/subproject/main/bootloader_start.c
AR build-GENERIC_SPIRAM/bootloader/libmain.a
LINK build-GENERIC_SPIRAM/bootloader.elf
Create build-GENERIC_SPIRAM/bootloader.bin
esptool.py v2.9-dev
Create build-GENERIC_SPIRAM/partitions.bin
mkdir -p build-GENERIC_SPIRAM/genhdr
GEN build-GENERIC_SPIRAM/genhdr/mpversion.h
GEN build-GENERIC_SPIRAM/genhdr/moduledefs.h
GEN build-GENERIC_SPIRAM/genhdr/qstr.i.last
GEN build-GENERIC_SPIRAM/genhdr/qstr.split
GEN build-GENERIC_SPIRAM/genhdr/qstrdefs.collected.h
QSTR updated
GEN build-GENERIC_SPIRAM/genhdr/qstrdefs.generated.h
GEN build-GENERIC_SPIRAM/genhdr/compressed.split
GEN build-GENERIC_SPIRAM/genhdr/compressed.collected
Compressed data updated
GEN build-GENERIC_SPIRAM/genhdr/compressed.data.h
mkdir -p build-GENERIC_SPIRAM/build-GENERIC_SPIRAM/
mkdir -p build-GENERIC_SPIRAM/drivers/bus/
mkdir -p build-GENERIC_SPIRAM/drivers/dht/
mkdir -p build-GENERIC_SPIRAM/extmod/
mkdir -p build-GENERIC_SPIRAM/extmod/nimble/
mkdir -p build-GENERIC_SPIRAM/lib/berkeley-db-1.xx/btree/
mkdir -p build-GENERIC_SPIRAM/lib/berkeley-db-1.xx/mpool/
mkdir -p build-GENERIC_SPIRAM/lib/embed/
mkdir -p build-GENERIC_SPIRAM/lib/littlefs/
mkdir -p build-GENERIC_SPIRAM/lib/mbedtls_errors/
mkdir -p build-GENERIC_SPIRAM/lib/mp-readline/
mkdir -p build-GENERIC_SPIRAM/lib/netutils/
mkdir -p build-GENERIC_SPIRAM/lib/oofatfs/
mkdir -p build-GENERIC_SPIRAM/lib/timeutils/
mkdir -p build-GENERIC_SPIRAM/lib/utils/
mkdir -p build-GENERIC_SPIRAM/py/
CC ../../py/mpstate.c
CC ../../py/nlr.c
CC ../../py/nlrx86.c
CC ../../py/nlrx64.c
CC ../../py/nlrthumb.c
CC ../../py/nlrpowerpc.c
CC ../../py/nlrxtensa.c
CC ../../py/nlrsetjmp.c
CC ../../py/malloc.c
CC ../../py/gc.c
CC ../../py/pystack.c
CC ../../py/qstr.c
CC ../../py/vstr.c
CC ../../py/mpprint.c
CC ../../py/unicode.c
CC ../../py/mpz.c
CC ../../py/reader.c
CC ../../py/lexer.c
CC ../../py/parse.c
CC ../../py/scope.c
CC ../../py/compile.c
CC ../../py/emitcommon.c
CC ../../py/emitbc.c
CC ../../py/asmbase.c
CC ../../py/asmx64.c
CC ../../py/emitnx64.c
CC ../../py/asmx86.c
CC ../../py/emitnx86.c
CC ../../py/asmthumb.c
CC ../../py/emitnthumb.c
CC ../../py/emitinlinethumb.c
CC ../../py/asmarm.c
CC ../../py/emitnarm.c
CC ../../py/asmxtensa.c
CC ../../py/emitnxtensa.c
CC ../../py/emitinlinextensa.c
CC ../../py/emitnxtensawin.c
CC ../../py/formatfloat.c
CC ../../py/parsenumbase.c
CC ../../py/parsenum.c
CC ../../py/emitglue.c
CC ../../py/persistentcode.c
CC ../../py/runtime.c
CC ../../py/runtime_utils.c
CC ../../py/scheduler.c
CC ../../py/nativeglue.c
CC ../../py/pairheap.c
CC ../../py/ringbuf.c
CC ../../py/stackctrl.c
CC ../../py/argcheck.c
CC ../../py/warning.c
CC ../../py/profile.c
CC ../../py/map.c
CC ../../py/obj.c
CC ../../py/objarray.c
CC ../../py/objattrtuple.c
CC ../../py/objbool.c
CC ../../py/objboundmeth.c
CC ../../py/objcell.c
CC ../../py/objclosure.c
CC ../../py/objcomplex.c
CC ../../py/objdeque.c
CC ../../py/objdict.c
CC ../../py/objenumerate.c
CC ../../py/objexcept.c
CC ../../py/objfilter.c
CC ../../py/objfloat.c
CC ../../py/objfun.c
CC ../../py/objgenerator.c
CC ../../py/objgetitemiter.c
CC ../../py/objint.c
CC ../../py/objint_longlong.c
CC ../../py/objint_mpz.c
CC ../../py/objlist.c
CC ../../py/objmap.c
CC ../../py/objmodule.c
CC ../../py/objobject.c
CC ../../py/objpolyiter.c
CC ../../py/objproperty.c
CC ../../py/objnone.c
CC ../../py/objnamedtuple.c
CC ../../py/objrange.c
CC ../../py/objreversed.c
CC ../../py/objset.c
CC ../../py/objsingleton.c
CC ../../py/objslice.c
CC ../../py/objstr.c
CC ../../py/objstrunicode.c
CC ../../py/objstringio.c
CC ../../py/objtuple.c
CC ../../py/objtype.c
CC ../../py/objzip.c
CC ../../py/opmethods.c
CC ../../py/sequence.c
CC ../../py/stream.c
CC ../../py/binary.c
CC ../../py/builtinimport.c
CC ../../py/builtinevex.c
CC ../../py/builtinhelp.c
CC ../../py/modarray.c
CC ../../py/modbuiltins.c
CC ../../py/modcollections.c
CC ../../py/modgc.c
CC ../../py/modio.c
CC ../../py/modmath.c
CC ../../py/modcmath.c
CC ../../py/modmicropython.c
CC ../../py/modstruct.c
CC ../../py/modsys.c
CC ../../py/moduerrno.c
CC ../../py/modthread.c
CC ../../py/vm.c
CC ../../py/bc.c
CC ../../py/showbc.c
CC ../../py/repl.c
CC ../../py/smallint.c
CC ../../py/frozenmod.c
CC ../../extmod/moduasyncio.c
CC ../../extmod/moductypes.c
CC ../../extmod/modujson.c
CC ../../extmod/modure.c
CC ../../extmod/moduzlib.c
CC ../../extmod/moduheapq.c
CC ../../extmod/modutimeq.c
CC ../../extmod/moduhashlib.c
CC ../../extmod/moducryptolib.c
CC ../../extmod/modubinascii.c
CC ../../extmod/virtpin.c
CC ../../extmod/machine_mem.c
CC ../../extmod/machine_pinbase.c
CC ../../extmod/machine_signal.c
CC ../../extmod/machine_pulse.c
CC ../../extmod/machine_i2c.c
CC ../../extmod/machine_spi.c
CC ../../extmod/modbluetooth.c
CC ../../extmod/modussl_axtls.c
CC ../../extmod/modussl_mbedtls.c
CC ../../extmod/modurandom.c
CC ../../extmod/moduselect.c
CC ../../extmod/moduwebsocket.c
CC ../../extmod/modwebrepl.c
CC ../../extmod/modframebuf.c
CC ../../extmod/vfs.c
CC ../../extmod/vfs_blockdev.c
CC ../../extmod/vfs_reader.c
CC ../../extmod/vfs_posix.c
CC ../../extmod/vfs_posix_file.c
CC ../../extmod/vfs_fat.c
CC ../../extmod/vfs_fat_diskio.c
CC ../../extmod/vfs_fat_file.c
CC ../../extmod/vfs_lfs.c
CC ../../extmod/utime_mphal.c
CC ../../extmod/uos_dupterm.c
CC ../../lib/embed/abort_.c
CC ../../lib/utils/printf.c
MPY _boot.py
MPY flashbdev.py
MPY _main.py
MPY inisetup.py
MPY apa106.py
MPY neopixel.py
MPY upip.py
MPY upip_utarfile.py
MPY ntptime.py
MPY dht.py
MPY ds18x20.py
MPY onewire.py
MPY uasyncio/init.py
MPY uasyncio/core.py
MPY uasyncio/event.py
MPY uasyncio/funcs.py
MPY uasyncio/lock.py
MPY uasyncio/stream.py
MPY webrepl.py
MPY webrepl_setup.py
MPY websocket_helper.py
GEN build-GENERIC_SPIRAM/frozen_content.c
CC build-GENERIC_SPIRAM/frozen_content.c
CC main.c
CC uart.c
CC gccollect.c
CC mphalport.c
CC fatfs_port.c
CC help.c
CC modutime.c
CC moduos.c
CC machine_timer.c
CC machine_pin.c
CC machine_touchpad.c
CC machine_adc.c
CC machine_dac.c
CC machine_i2c.c
CC machine_pwm.c
CC machine_uart.c
CC modmachine.c
CC modnetwork.c
CC network_lan.c
CC network_ppp.c
CC nimble.c
CC modsocket.c
CC modesp.c
CC esp32_partition.c
CC esp32_rmt.c
CC esp32_ulp.c
CC modesp32.c
CC espneopixel.c
CC machine_hw_spi.c
CC machine_wdt.c
CC mpthreadport.c
CC machine_rtc.c
CC machine_sdcard.c
CC modpycom.c
CC pin_def_change.c
CC moduqueue.c
CIRCLEQ_ENTRY(_bkt) hq; /* hash queue /
CIRCLEQ_HEAD(_lqh, _bkt) lqh; / lru queue head */
DB *db = __bt_open(MP_OBJ_TO_PTR(pos_args[0]), &btree_stream_fvtable, &openinfo, /dflags/ 0);
../../lib/berkeley-db-1.xx/PORT/include/db.h:230:5: note: expected 'int' but argument is of type 'BTREEINFO * {aka struct *}'
marcidy
Post by marcidy » Wed Apr 14, 2021 6:06 am
please see this post: viewtopic.php?f=18&t=10225
