What is the differences between the binary distributions for the ESP32 on this site?
I have read that the SPIRAM is an ESP32 with external ram, however I'm at loss what the differences are with the others.
Regards John
Binary differences for ESP32 on this site.
Re: Binary differences for ESP32 on this site.
GENERIC : esp32-20210425-unstable-v1.15-13-g530c76f6c.bin
GENERIC : esp32-20210423-unstable-v1.15-4-g5669a6095.bin
GENERIC : esp32-20210423-unstable-v1.15-3-g00d6a79b3.bin
GENERIC : esp32-20210421-unstable-v1.15-2-g6e0f9b926.bin
GENERIC : esp32-20210420-unstable-v1.15.bin
GENERIC : esp32-20210419-unstable-v1.15.bin
GENERIC : esp32-20210418-v1.15.bin
<architecture>-<date compiled>-[stability]-<micropython release version>-[micropython minor version]-g[git commit].bin
If you want to test upcoming release candidates, check unstable ones.
Thank you or your reply, I was also interested in the differences between
esp32-idf4 (builds)
and
esp32-20210418-v1.15.bin (builds)
Reason being it seems the non idf4 (builds) do not seem to have the umqtt module
Regards John
esp32-idf4 (builds)
and
Regards John
idf4 is the version of the esp-idf that the firmware uses. previously 4 wasn't supported, and now it is, so I assume that is to mark the epoch for esp-idf 4 in 1.14 versions where the transition from 3.3 to 4 occurred. 1.15 uses esp-idf 4+ only, so no need to identify esp-idf versions in 1.15 micropython builds.
I don't use the mqtt module so not sure, i don't track it's movements.
If you aren't using a release version, there's likely to be changes while migrations occur. IF you need stability, stick to full releases (e.g. v1.14, v1.15, etc).
