Post
by Geranimo » Fri Apr 08, 2022 6:10 am
I clearly see that there is something with Enterprise, but i sadly cant find a example how to use it.
>>> dir(network)
['__class__', '__init__', '__name__', 'AP_IF', 'AUTH_MAX', 'AUTH_OPEN', 'AUTH_WEP', 'AUTH_WPA2_ENTERPRISE', 'AUTH_WPA2_PSK', 'AUTH_WPA2_WPA3_PSK', 'AUTH_WPA3_PSK', 'AUTH_WPA_PSK', 'AUTH_WPA_WPA2_PSK', 'ETH_CONNECTED', 'ETH_DISCONNECTED', 'ETH_GOT_IP', 'ETH_INITIALIZED', 'ETH_STARTED', 'ETH_STOPPED', 'LAN', 'MODE_11B', 'MODE_11G', 'MODE_11N', 'PHY_DP83848', 'PHY_IP101', 'PHY_LAN8720', 'PHY_RTL8201', 'PPP', 'STAT_ASSOC_FAIL', 'STAT_BEACON_TIMEOUT', 'STAT_CONNECTING', 'STAT_GOT_IP', 'STAT_HANDSHAKE_TIMEOUT', 'STAT_IDLE', 'STAT_NO_AP_FOUND', 'STAT_WRONG_PASSWORD', 'STA_IF', 'WLAN', 'phy_mode']
