BME280.py vs bmp280.py
peterevans
Post by peterevans » Fri May 21, 2021 4:07 pm
I am using a little bme/bmp280 sensor from aliexpress and have been trying out BMP280.py and bmp280.py and I find that their is a descrepency of about 10 hpa in the atmostpheric pressure by just changing the drivers. I am not sure if I should be making calibration changes to the software in the BMP280.py or could I do some changes in the main.py file.
Re: BME280.py vs bmp280.py
Post by Roberthh » Fri May 21, 2021 4:17 pm
Could you give the full URL path of the two respective drivers you are using. Otherwise comparison is difficult.
peterevans
Post by peterevans » Sat May 22, 2021 4:49 am
I tried the randomnerd tutorial driver :
https://randomnerdtutorials.com/micropy ... -esp8266/
Randomnerd driver gave me Temp:30.80 C Humidity: 56.3% Pressure 997.83 hPa
I felt this was too low compared to the weather maps which were around 1008 hPa.
I tried this one which required a few tweaks to get working for temperature and pressure but I couldn't get humidity to work:
https://github.com/dafvid/micropython-bmp280
and it gave me temperature of 31.32 and pressure of 1007.45 hPa
I tried another driver today from neliogodoi which seemed easier to set up:
https://github.com/neliogodoi/MicroPython-BME280
These produced ('31.1 C', '100674.4 Pa', '56.13183 %')
Post by Roberthh » Sat May 22, 2021 6:52 am
Hard to tell without a reliable reference. I also derived a BME280 driver and did a careful review and fox on how the calibration data was read from the device. You'll find it here: https://github.com/robert-hh/BME280
It has a float and int variant. The int variant follows the datasheet of Bosch and avoids rounding errors. For all practical purposes, the results are identical. When testing my driver, I compared the result with the values reported by the nearby university weather station. I used a calm day with low wind for the test. The results were close, but not identical. Reason: The university publishes pressure normalized to the sea level, and I could not get exactly the height over ground of both the university weather station and my place. But the pressure difference I got was in the range of uncertainty of the height over sea level.
peterevans
Post by peterevans » Sat May 22, 2021 7:46 am
Thanks so much.
It is very helpful. I have now searched around for more drivers and found several that give results closer to what I am expecting.
I am confident now that it isn't the sensor that is causing the differences low pressure values.
I tried your driver https://github.com/robert-hh/BME280 and it gives me results that I feel happy with.
Thank you again for your help.
