Suddenly no response from REPL
lgyer
Post by lgyer » Mon May 24, 2021 2:53 am
Hi guys,
I am a novice of Micropython.
I ran into a problem about the REPL. When I use the REPL to go into raw mode and type commands repeatly, the REPL does not display any output sometimes. And CTRL+C does not respond. When I use CTRL+D to restart the hardware, but there is still no log output after restarting. Only by shutting down the hardware and then turning it back on can it return to normal.
My board is M5Stack Core and micropython's version is v1.12.
lgyer
Re: Suddenly no response from REPL
Post by lgyer » Mon May 31, 2021 8:24 am
Does anyone have any ideas?
davef
Post by davef » Mon May 31, 2021 8:57 am
On re-reading this ... do you mean when no program is running and that you are running rshell.
lgyer
Post by lgyer » Tue Jun 01, 2021 2:43 am
Hi davef
Thanks for your reply.
There was some code running, such as led blink.
davef
Post by davef » Tue Jun 01, 2021 3:12 am
Ah, I saw a post somewhere about the same issue.
CTRL C stops a running program which puts you in raw repl.
Then CTRL X gets you back to /pyboard/ so that you can then edit files
CTRL D will soft re-boot the device.
