I am trying to make use of "rtc.init()" function to set the time, date, and timezone on my ESP32 device.
First question:
Looking at the documentation(1) I see the following:
(year, month, day[, hour[, minute[, second[, microsecond[, tzinfo]]]]])
I also can not set a negative value, which seems odd.
So how can I set a timezone?
Second question:
If I use valid data and any positive integer for "tzinfo" field to set the RTC.
The output I get from "rtc.now()" confuses me.
Actual output:
(2021, 5, 29, 5, 10, 40, 23, 238401)
(2021, 5, 29, 5, 11, 0, 38, 88400)
(2021, 5, 29, 5, 17, 29, 2, 578398)
(2021, 5, 30, 6, 9, 49, 12, 348377)
(2021, 5, 30, 6, 18, 35, 39, 248372)
YYYY MM DD ?? HH MM SS MS
What exactly is the fourth field?
Times and dates reported were correct for my location in the above example.
I think it's defined in the source code in "machine_rtc.c" (2)
Tho I am not 100% sure
References:
(1) https://micropython-docs-esp32.readthed ... e.RTC.html
(2) https://github.com/micropython/micropyt ... hine_rtc.c
