I2C not working
lormayna
I2C not working
Post by lormayna » Mon May 31, 2021 9:21 pm
I am trying to work with a BMP280 on a ESP32-DEVKIT-V1, but I am getting this error:
>>> from machine import I2C, Pin
>>> bus = I2C(scl=Pin(21), sda=Pin(22))
>>> bus.scan()
[8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 5]
Sometimes bus.scan() return only an empty array.
Those are my device's details:
>>> import os
>>> os.uname()
(sysname='esp32', nodename='esp32', release='1.13.0', version='v1.13 on 2020-09-02', machine='ESP32 module with ESP32')
What I am doing wrong?
marcidy
Re: I2C not working
Post by marcidy » Tue Jun 01, 2021 3:53 am
I don't know if it's necessary, but I pass pull=Pin.PULL_UP when I declare the pins.
	i2c_bus = I2C(freq=400000, scl=Pin(15, pull=Pin.PULL_UP), sda=Pin(4, pull=Pin.PULL_UP))
Check the electrical connections and power to make sure there's sufficient power to the device.
Re: I2C not working
Post by Roberthh » Tue Jun 01, 2021 7:11 am
It looks like a wiring problem. So either the pull-up resistors are missing, or the wires are swapped, or you forgot to connect GND, or the BMP280 is not powered, or the BMP280 is set to SPI mode. Most BMP280 breakout boards have pull-up resistors implemented. If not, add some. 4.7 kOhm is a good compromise. Using the built-in pullup of the ESP32 may work with low baud rates, like 10000.
srbpavel
Re: I2C not working
Post by srbpavel » Sat Jun 12, 2021 10:38 am
hallo lormayna, as robertHH is mentioning: check for short circuit
i had the same experiences with lot's of i2c addresses when some of my machines were outside under the roof in dry place, but during the spring humidity was going up.
- after moving the machine in lab to dry conditions, all works well. so, short circuit.
pavel
