Hi all, Im getting some rare messages when I try to set to both, I mean if or ext0 (@ Pin 15 for instance) wakeup or touch ( Pin(32) for instance).
I ve read some references that with rev 0 and rev1 we cannot set both at the same time to wake if happened one or the other reason.
https://docs.espressif.com/projects/esp ... ep%20modes
In revisions 0 and 1 of the ESP32, this wakeup source is incompatible with ULP and touch wakeup sources.
I ve set code like:
MicroPython v1.14-119-g6e5aea08a-dirty on 2021-04-15; ESP32 @2021 (spiram) with ESP32-8MB
>>> import lib_full as lib
>>> sensor1 = lib.machine.Pin(15, lib.machine.Pin.IN, lib.machine.Pin.PULL_UP) # sensor INT1
>>> wake = lib.machine.Pin(32, mode = lib.machine.Pin.IN)
>>> touch = lib.machine.TouchPad(wake)
>>> touch.config(500)
>>> lib.esp32.wake_on_ext0( lib.machine.Pin(15), level = lib.esp32.WAKEUP_ANY_HIGH)
>>> lib.esp32.wake_on_touch(True)
ValueError: no resources
test module is a wrover-e, rev3 flashed compiled with spiram enabled
can anyone confirm if with rev 3 and Mpy 1.15 or similar I could set to wakeup combining those wakes touch and ext0 (or ext1) ?
thanks in advance.
M
combined touch and ext0 wakes get "ValueError: no resources" ?
Re: combined touch and ext0 wakes get "ValueError: no resources" ?
some other reference suggesting use ext1 as a workaround but it doesn't work either/
>>> sensor2 = lib.machine.Pin(2, lib.machine.Pin.IN, lib.machine.Pin.PULL_UP) # sensor INT2
>>> lib.esp32.wake_on_ext1(( lib.machine.Pin(34), lib.machine.Pin(2)), level = lib.esp32.WAKEUP_ANY_HIGH)
ext0 is explicitly incompatible with wake on touch in micropython. Just reading the code, i don't see anything preventing use with ext1 (I have no idea if it will work from a hardware perspective)
You might want to try a hard reset (e.g. rst pin or full power off) when experimenting with ext1. I don't see anything which should trigger the error when using ext1, however, a soft reset doesn't reset all registers etc, so if you have not hard reset after setting ext0 config, you'll still see the error.
So if you are running something on reboot (ie main.py, etc) that configured ext0, you'll never be able to experiment with ext1 since ext0 always gets configured.
I haven't tried this, just reading the code and having faced similar issues with registers on soft reboot leads me to think this may be the case.
