Send user message after webrepl connection
Patrice
Post by Patrice » Thu Jun 10, 2021 5:18 am
I want to send some user and informations messages on WebREPL as soon as the connection is done, just after the message "WebREPL connected".
Is it possible ?
davef
Re: Send user message after webrepl connection
Post by davef » Thu Jun 10, 2021 7:29 am
webrepl.start()
utime.sleep(20)
print('hi there')
The problem I see is that you need the user to login first and before the 20 seconds are up! Maybe, there is a way that you can login with a stored or no password.
marcidy
Post by marcidy » Thu Jun 10, 2021 8:22 pm
If you look at extmod/webrepl.py, you'll see how the webrepl is set up with a callback on connection.
Since this is just python code, you can duplicate it into you're own version of the webrepl, and you won't need to recompile the firmware to modify it.
just copy extmod/webrepl.py to your own module, let's say "mywebrepl". Then you can use
>>> import mywebrepl
>>> mywebrepl.start(password="whatever")
Then you can modify the accept_conn to send whatever you'd to the websocket on connection after the handshake.
Patrice
Post by Patrice » Fri Jun 11, 2021 6:20 am
Tanks, I'll try that !
