The project I am working on is a bit large and I do not know at what point in the code this is taking place. I do have debugging information that is supposed to be output but it is not happening at all. I have been cleaning up some coding mistakes so I know what areas should be OK. It appears to be a problem when I start the WiFi up. On the downloads page it states that LAN is not available using 4.x , I didn't think that the ESP has LAN functionality at all so either it is a typo and should read WiFi or WiFi is supported and LAN means something else.
▒Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x401d98a7 PS : 0x00060b30 A0 : 0x800fdeb6 A1 : 0x3ffcc6e0
A2 : 0x3ffcc810 A3 : 0x00000000 A4 : 0x3f8202f0 A5 : 0x00000000
A6 : 0x00000030 A7 : 0x00000030 A8 : 0x801d984c A9 : 0x00000000
A10 : 0x3ffcc810 A11 : 0x00000000 A12 : 0x3ffc3da4 A13 : 0x00060021
A14 : 0x000000fe A15 : 0x00000001 SAR : 0x0000001c EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000020 LBEG : 0x40092f5a LEND : 0x40092f65 LCOUNT : 0x00000000
Backtrace:0x401d98a4:0x3ffcc6e0 0x400fdeb3:0x3ffcc710 0x400fdf1d:0x3ffcc730 0x400fe38a:0x3ffcc750 0x400fe591:0x3ffcc770 0x400ff946:0x3ffcc7a0 0x400fe591:0x3ffcc7c0 0x4010097b:0x3ffcc7f0 0x40101181:0x3ffcc810 0x400e27d3:0x3ffcc870 0x400fd9c9:0x3ffcc900 0x400fdcd7:0x3ffcc930 0x400e2906:0x3ffcca10 0x400e30e7:0x3ffcca50 0x400e52fd:0x3ffccab0 0x400dc1f0:0x3ffccb50 0x400e2731:0x3ffccba0 0x400e275a:0x3ffccbc0 0x400e27de:0x3ffccbe0 0x400fd9c9:0x3ffccc70 0x400fdcd7:0x3ffccca0 0x400e2906:0x3ffccd80 0x400e30e7:0x3ffccdc0 0x400e52fd:0x3ffcce20 0x400dc1f0:0x3ffccec0 0x400e2731:0x3ffccf20 0x400e275a:0x3ffccf40 0x400e27de:0x3ffccf60 0x400fd9c9:0x3ffccff0 0x400fdd66:0x3ffcd020 0x400e2906:0x3ffcd100 0x400e52ca:0x3ffcd140 0x400dc1f0:0x3ffcd1e0 0x400e2731:0x3ffcd230 0x400e275a:0x3ffcd250 0x400f5c76:0x3ffcd270 0x400f6041:0x3ffcd300 0x400f60a5:0x3ffcd320 0x400d5ce2:0x3ffcd340
ELF file SHA256: cfb0f5586b7de139
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:5640
load:0x40078000,len:13136
load:0x40080400,len:4356
entry 0x400806b0
Rebooting...
entry 0x400806b0
Rebooting...
Oh after many many times of the core panic happening it finally booted and I am getting an error when i set the WiFi authentication mode to WEP.
RuntimeError: Wifi Unknown Error 0x0102
