Error reading return content
Rat_financial
Post by Rat_financial » Sun Jul 18, 2021 3:47 pm
currently using google app script
When using python post , it returns json normally but when using micropython post it returns html
code:
import prequests as requests
headers = {'Content-Type': 'application/x-www-form-urlencoded'}
upload = {"data": "88"}
res = requests.post(url, json = upload, headers = headers)
print(res.text)
Reason: Add [code] formatting
marcidy
Re: Error reading return content
Post by marcidy » Sun Jul 18, 2021 5:00 pm
It would be helpful if you posted what you received, and what the server "normally" sends back. You really should inspect the full response to see if it's the same with both python and micropython, to see if the problem is with processing the response or with the request itself.
Also I have no idea what prequests is or how it's written so can't really help with it. Where did you get it?
Using code tags (the </> button) around your code makes it much easier to read on the forum.
Post by jimmo » Mon Jul 19, 2021 1:52 am
I think this has come up before, and what we found is that the HTML returned is actually an error page. (And hopefully that will explain what's going on). Perhaps a missing header that Python is setting, but MicroPython isn't?
I also notice that you're telling the server that it's form-urlencoded data but sending JSON... Maybe Python's request fixes that for you.
See viewtopic.php?f=18&t=6492
Rat_financial
Post by Rat_financial » Mon Jul 19, 2021 3:05 am
use python status_code = 200 , but use micropython status_code = 405
but The information is normal post
prequests.py form https://gist.github.com/SpotlightKid/86 ... 41dd269c44
marcidy
Post by marcidy » Mon Jul 19, 2021 7:51 pm
402 implies the server doesn't like the request, and I think jimmo's point is worth looking into. Looking at (macro)python's requests , it does switch the content-type if the json parameter is not none.
from requests.models.py:
        if not data and json is not None:
            # urllib3 requires a bytes-like body. Python 2's json.dumps
            # provides this natively, but Python 3 gives a Unicode string.
            content_type = 'application/json'
            # Multi-part file uploads.
            if files:
                (body, content_type) = self._encode_files(files, data)
                if data:
                    body = self._encode_params(data)
                    if isinstance(data, basestring) or hasattr(data, 'read'):
                        content_type = None
                        content_type = 'application/x-www-form-urlencoded'
so try switching content-type to `application/json`.
