Compiled binary of micropython
How to compile the micropython .py file into a binary file and later import it to main.py?
- OlivierLenoir
Re: Compiled binary of micropython
Look for mpy-cross, documentation is available here
Olivier Lenoir
https://gitlab.com/olivierlenoir
Thanks for the solution, I have created .mpy file in host computer, how to copy it to ESP32 board? Thonny only supports .py file to upload.
I've copied files other than .py with Thonny before. Using the file panel on the left, right-click the file you want to copy on the local drive at the top of the panel then and select Upload to / (or whatever the cwd of the device is).
Alternatively you can use WebREPL or the new mpremote CLI tool:
mpremote cp myfile.mpy :
John Sheehan
how to add esp32 board micropython custom function with the micropython firmware (.bin)? How can we build custom micropython firmware?
