webrepl problem
mmx64
webrepl problem
Post by mmx64 » Wed Sep 15, 2021 8:04 am
Hello, im trying to setup webrepl on my bord, loin32
boot.py
# This file is executed on every boot (including wake-boot from deepsleep)
#import esp
#esp.osdebug(None)
yourWifiSSID = "xxx"
yourWifiPassword = "xxx"
def connect():
    if not sta_if.isconnected():
        sta_if.active(True)
        sta_if.connect(yourWifiSSID, yourWifiPassword)
            pass
def showip():
    print('network config:', sta_if.ifconfig())
connect()
time.sleep(5)
showip()
import webrepl
webrepl.start()
print("waiting 5s...")
time.sleep(5)
print("boot completed...")
main loop in main.py
            message = CAN.read_message()
            if message:
                print_frame(message["id"],message["data"])
                if message["id"] not in IDS:
                    IDS.append(message["id"])
                print(message["id"], message["data"])
                print(IDS)
        except OSError as E:
            print("ERROR_IN_MAIN_LOOP",E)
            machine.reset()
my problem is if i dont start the main looop i can connect via webrepl, asks for password, if i enter enter wrong password im am disconnected, if i enter good password im redirected to repl but i cannot add any input its frozen.
serial repl
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:5652
load:0x40078000,len:12696
load:0x40080400,len:4292
entry 0x400806b0
connecting to network...
Brownout detector was triggered
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400806b0
network config: ('192.168.1.152', '255.255.255.0', '192.168.1.1', '192.168.1.1')
WebREPL daemon started on ws://192.168.1.152:8266
Started webrepl in normal mode
waiting 5s...
boot completed...
Entering configuration mode...
mode already set
calulating BRP and setting configuration registers 1, 2 and 3
Entering normal mode...
mode sucessfully set
MicroPython v1.17-20-g0a5107372-dirty on 2021-09-11; ESP32 GENERIC-7789 with ESP32
WebREPL connection from: ('192.168.1.249', 63110)
dupterm: EOF received, deactivating        ------------------>enter wrong password
WebREPL connection from: ('192.168.1.249', 51843) --------------------------->enter correct password
webrepl interface downloaded from github
Welcome to MicroPython!
Password:
Access denied
Disconnected
Password:
WebREPL connected
>>>    ------------------->cannot enter any input
If i start loop in main.py i cannot connect to webrepl at all.
Any fix for my problem. Thanks!
marcidy
Re: webrepl problem
Post by marcidy » Fri Sep 17, 2021 3:54 am
You can't both execute your loop in the foreground AND use the repl in the foreground. At a minimum you need to use concurrency of some kind, ie another thread.
For example, this doesn't work over USB, and doesn't work in normal python either.
>>> def main():
>>>     while True:
>>>         print("haha, im blocking you")
>>> main()
won't let you use the repl in python.
You should be able to use ctrl-C to interrupt the processing after connecting to the webrepl ... eventually. You are at the whim of the scheduler to eventually handle the input over the socket. using time.sleep(.01) in your loop will give the scheduler a nice point to handle some input.
