Powering ESP32-S2 from a single Li-ion cell
mathieu
Post by mathieu » Wed Sep 15, 2021 7:44 pm
I just got a S2 Mini board, and I'm trying to power it from a single 18650 Li-ion cell. The 18650 is the input of a HT7333 LDO regulator which nominally outputs 3.3 V. My battery input is ~3.89 V, my output is ~3.25 V, but something does not work as intended (the board should be requesting a URL and it is not doing so). I added 10 uF capacitors to the input and/or output of the HT7333 but no luck.
The board works from time to time, for no obvious reason. I suspect this is a power issue, as the same board works flawlessly when powered from USB.
What would be a simple, reliable method to power this board from the 18650?
Online
davef
Re: Powering ESP32-S2 from a single Li-ion cell
Post by davef » Wed Sep 15, 2021 9:40 pm
I put 1000uF low-ESR caps on my 26V to 5V SMPS outputs, which are capable of 5A peaks . I also use some 1.5A SMPS buck supplies, which seem to work as well.
Max output current 250mA! Have you got a DSO?
Online
davef
Post by davef » Wed Sep 15, 2021 9:58 pm
I'd check that any internal current limiter in the HT7333 can handle charging up a 1000uF at turn-on. I didn't see anything relevant in the datasheet.
mathieu
Post by mathieu » Tue Sep 21, 2021 8:32 am
Thanks for the feedback.
For the record, after exploring a number of options I went with the following option: connect the Li-ion battery to the 3V3 pin of the S2 mini through a silicon diode. The S2 should see voltages in the range of 2.9-3.5 V, which is within specs. This solution is very simple to implement, and should be very energy-efficient
wangshujun@tom.com
Post by wangshujun@tom.com » Tue Sep 28, 2021 7:58 am
Ht7333 is a LDO with large voltage difference, which is not suitable for this occasion
The better LDO I used before is tps74701, but now it has been replaced with tps63000 DCDC
elschopi
Post by elschopi » Thu Sep 30, 2021 10:34 am
Not only maximum cell voltage needs to be taken into account, I'd also consider the lower limits of the cell. If battery efficient operation isn't needed, one could use a TP4056 based charging / protection board (which would also handle charging the cell, but then you'll need a relay / FET to disconnect the load while charging) and a step-up board that steps the (say) 2.5 to 4.2 V from the cell up to clean 5V.
I do that when I use ESP32 based dev boards (ESP32 DevKit C, Heltec Wireless Stick) in non-critical testing setups or if backed by solar cells.
In general, you'll want a low dropout, wide input range LDO with a very low quiescent current to maximize efficency.
There's also a excellent video on the topic by Andreas Spieß over on Youtube: https://www.youtube.com/watch?v=FrCgQgahzsI
Also if your cell does not have protection included, you should implement it in your design. DW01-P can be used for that. (https://cdn.sparkfun.com/assets/learn_t ... et_V10.pdf)
best regards,
Chris
