ESP32: get which EXT1 pin caused wake
karfas
Re: ESP32: get which EXT1 pin caused wake
Post by karfas » Sun Oct 17, 2021 7:23 am
@roberthh: This is great!
I propose to wait a week or so to collect some more opinions and then create a PR from your code.
For me, a tuple of pin numbers looks sufficient.
@sergei.nz: I don't care about convenience. A few lines of more user code to decode the bitmap is better than not having this information at all. My arguments were about consistency of the interface. The current micropython docs mention the term "bitmap" exactly twice (for memory management and some framebuffer function), so it just felt ugly/wrong for me to return the bitmap to users.
karfas
Post by karfas » Sat Nov 06, 2021 9:38 am
@roberthh: is it OK for you when I create the PR and documentation change ?
Online
Post by Roberthh » Sat Nov 06, 2021 10:37 am
Sure.
karfas
Post by karfas » Sun Nov 14, 2021 10:43 am
karfas
Post by karfas » Sun Feb 27, 2022 6:14 pm
New PR is in https://github.com/micropython/micropython/pull/7990
The PR is ready, tested and works (both GPIOs 2+4 connected to the same button):
>>> import main1
Reset: Wakeup from deep sleep
wakeup_reason(): (2, 4)
Going to sleep
My test program:
from machine import Pin, TouchPad
import esp32
import esp
    print("Reset: Wakeup from deep sleep")
    print("Reset: Other reason")
print("wakeup_reason(): {}".format(machine.wake_ext1_pins()))
pin4 = Pin(4, mode = Pin.IN, pull = Pin.PULL_DOWN)
wake = Pin(2, mode = Pin.IN, pull = Pin.PULL_DOWN)
esp32.wake_on_ext1(pins = [wake,pin4], level = Pin.WAKE_HIGH)
time.sleep(2)
print('Going to sleep')
machine.deepsleep()
bwyld
Post by bwyld » Tue Sep 05, 2023 2:40 pm
Just wondered if anyone had tested this with lightsleep() and/or on an ESP32S3?
I am having some difficulty using gpios to wake from light sleep and call the irq() callback associated with the pin.
