Thank you Roberthh .Nice to have someone like you to help us .
The fully working program for other beginners like me. Switches an LED on off via touch
"""ILI9341/xpt2046 demo _ESP32 defkitV1"""
#connection on ESP32
#TFT-----------------Touch
# MISO = 19------= 12
# MOSI =23-------= 13
# clk =18---------- = 14
# CS = 5---------- = 15
# Rst = 33------- T-IRQ = NC
# led = 25
from time import sleep
from ili9341 import Display, color565
from xglcd_font import XglcdFont
import xpt2046_syn
led = Pin(25 , Pin.OUT)
spi = SPI(2, baudrate=40000000, sck=Pin(18), mosi=Pin(23))
display = Display(spi, dc=Pin(27), cs=Pin(5), rst=Pin(33))
print('Loading fonts...')
print('Loading espresso_dolce')
espresso_dolce = XglcdFont('font/EspressoDolse18x24.c',18 , 24)
print('Fonts loaded.')
def test():
display.fill_rectangle(50, 20, 150, 280, color565(0,255,255))
display.draw_text(80, 50, ' select ', espresso_dolce , color565(255,255,255))
display.draw_text(80, 150, ' LED_on ', espresso_dolce , color565(0,0,0),
background=color565(255, 0, 100))
display.draw_text(80, 200, ' LED_off ' ,espresso_dolce, color565(0, 0, 0),
background=color565(0, 0, 255))
test()
spi = machine.SPI(1, baudrate=1000000, miso=machine.Pin(12), mosi=machine.Pin(13), sck=machine.Pin(14))
ts_cs = machine.Pin(15, machine.Pin.OUT)
touch = xpt2046_syn.XPT2046(spi = spi, confidence=5, margin=50, delay=10, calibration=None)
ts_cs.value(0)
res = touch.get_touch(initial=False, wait=True, raw=False, timeout=300)
if res is not None:
x_value,y_value = res
continue
if x_value > 170 and x_value < 300:
if y_value > 120 and y_value < 130:
led(1) #set led on
if y_value > 70 and y_value < 90:
led(0) #set led off
print(str(x_value)) #print x_value on Shell
print(str(y_value)) #print y_value on Shell
search working well progam for xpt2046
Re: search working well progam for xpt2046
Last edited by yellowpowerplay on Fri Oct 29, 2021 4:40 pm, edited 1 time in total.
- custom_resized_.jpg (202.57 KiB) Viewed 871 times
