Need help with a script
Posted: Sun Nov 14, 2021 6:22 pm
by codehobby
I'm from from France (I didn't really find a forum in French so here I am)
I have an ESP32 and ws2812 led, I'd like to create a fade in/out effect with the color I want. I started a code but it doesn't work also I'm a big beginner in coding. Here is my code :
import machine, time, neopixel
n = 5 #number of led
p = 13 #Pin number on the board
freq = 5000 #frequency
np = neopixel.NeoPixel(machine.Pin(p), n) #neopixel object
led = machine.PWM(machine.Pin(p), freq) #PWM object
    #color rgb
    r = 103
    g = 202
    b = 232
    for i in range(n):
        np[i] = (r, g, b)
        np.write()
    for duty_cycle in range(0, 1024, 10):
        led.duty(duty_cycle)
        time.sleep(0.05)
    for duty_cycle in range(1024, 0, -10):
        time.sleep(0.05)
Help would be much appreciated.
Thanks.
Re: Need help with a script
Posted: Mon Nov 15, 2021 2:29 am
by marcidy
    #color rgb
    r = 103
    g = 202
    b = 232
    for i in range(n):
        np[i] = (r, g, b)
        np.write()
This above snipped is (almost) the correct use of the NeoPixel driver.
First, remove the PWM config:
# This correctly instantiates a NeoPIxel controller
# This creates a PWM on the same pin, effectively undoing any specific configuration of the pin required for the NeoPIxel.  Remove this line.
Second, unindent the np.write call, it only needs to be called once to send the data to the strip. Filling the array creates the command string for the strip. np.write sends the command string.
    # Fill the array, one color tuple for each LED
    for i in range(n):
        np[i] = (r, g, b)
    # send entire array of colors to LED strip all at once
    np.write()
And the "while True" is not doing anything here as you are not changing the color in the while loop.
Do this:
    #color rgb
r = 103
g = 202
b = 232
for i in range(n):
    np[i] = (r, g, b)
np.write()
All of the rest is incorrect for addressable LEDS and unneeded.
        time.sleep(0.05)
        time.sleep(0.05)
PWMs control brightness by rapidly turning the LED on and off. Addressible LEDs take commands as each individual LED has a controller on the strip or in the LED. You send them commands only, you cannot control them via PWM.
Posted: Mon Nov 15, 2021 4:39 pm
by codehobby
Ok, thanks. I found 2 programs on which you can set the brightness but it's only for red, and white color.
Posted: Wed Nov 17, 2021 6:24 pm
by marcidy
addressable LEDs are effectively 3 LEDS, red, green and blue.
The number you are setting IS the brightness of the LED. So you can manipulate that number to change the brightness. (so now you would need a loop).
Dealing with brightness in RGB color space is painful, I suggest looking up how to use HSV color space instead and convert to/from RGB. I'm sure someone in the world has figured it out, but here's some functions which can help.
def rgb_to_hsv(r, g, b, base=255):
    if base <= 0:
        raise ValueError("Base must be strictly positive in rgb_to_hsv")
    r = float(r)/base
    g = float(g)/base
    b = float(b)/base
    high = max(r, g, b)
    low = min(r, g, b)
    h, s, v = (high, high, high)
    chroma = high - low
    s = 0 if high == 0 else chroma/v
    if high == low:
        h = 0.0
        return h, s, v
    elif r == high:
        h = (((g-b)/chroma) % 6) / 6
        return h, s, v
    elif g == high:
        h = ((b-r)/chroma + 2) / 6
        return h, s, v
    elif b == high:
        h = ((r-g)/chroma + 4) / 6
        return h, s, v
def hsv_to_rgb(h, s, v, base=255):
    if s == 0.0:
        ret = (v, v, v)
    i = int(h*6.)  # XXX assume int() truncates!
    f = (h*6.)-i
    p, q, t = v*(1.-s), v*(1.-s*f), v*(1.-s*(1.-f))
    i %= 6
    if i == 0:
        ret = (v, t, p)
    if i == 1:
        ret = (q, v, p)
    if i == 2:
        ret = (p, v, t)
    if i == 3:
        ret = (p, q, v)
    if i == 4:
        ret = (t, p, v)
    if i == 5:
        ret = (v, p, q)
    return (int(ret[0]*base), int(ret[1]*base), int(ret[2]*base))
Posted: Thu Nov 18, 2021 10:50 am
by codehobby
Ok, I'll take a look at it. Thanks
Posted: Sun Nov 21, 2021 2:11 am
by Edison Franco
Hi, could you share these examples? Thanks!
Posted: Fri Nov 26, 2021 4:45 pm
by codehobby
