file.flush() causes a crash
Posted: Fri Nov 26, 2021 9:36 am
Hi.
I'm working on a weather station project and it uses the ESP32's RTC memory. I added a function (rtcmem.saveSession()) that dumps the content of the RTC memory (as a string) and writes it to a file when the node is about to go to deep sleep. Then, upon startup, if a crash was detected, I can use this file to restore the memory contents.
Recently, I decided to take some parts of my code (including the one that manages the RTC memory) and compile it with mpy-cross. This change however, introduced a "bug". I noticed that sometimes the node crashes when it tries to run rtcmem.saveSession().
This is the code for the saveSession function:
Since, I can't really debug the code, I just added a print(".") statement after each line inside the try block. It turns out, that contentDump.flush() is what caused the crash.
Removing the flush() call doesn't help, because then close() causes a crash. It probably tries flushing too.
Could someone please explain what is going on? Is there a bug in how MicroPython handles file I/O or the issue is something else?
def saveSession(self, ignoreEmpty=False):
if self.readMemory(True) == dict():
if not ignoreEmpty:
raise Exception("Cannot save empty memory, use ignoreEmpty arg to ignore this")
return
contentDump = open("/rtcmem.dump", "w")
content = self.readMemory(True)
#content will be a Python dictionary
content = str(content)
contentDump.write(content)
contentDump.flush()
contentDump.clse()
except Exception as ex:
contentDump.close()
self.deleteSessionFiles()
raise ex
rtcmm_log("debug", "RTC session files saved")
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4018c603 PS : 0x00060430 A0 : 0x800eef90 A1 : 0x3ffb75c0
A2 : 0x00810008 A3 : 0x3ffb7620 A4 : 0x0000000c A5 : 0x3f817984
A6 : 0x00000860 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x00000001
A10 : 0x00000001 A11 : 0xff7f0000 A12 : 0x00810000 A13 : 0x00000001
A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000010 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00810008 LBEG : 0x4008b919 LEND : 0x4008b93b LCOUNT : 0xffffffff
ELF file SHA256: 57ae9103722b1711
Backtrace: 0x4018c600:0x3ffb75c0 0x400eef8d:0x3ffb75e0 0x400ef8e2:0x3ffb7690 0x400f0069:0x3ffb76e0 0x400ec051:0x3ffb7700 0x400dd0a1:0x3ffb7720 0x400e353d:0x3ffb7740 0x400e3672:0x3ffb7760 0x400ea9fd:0x3ffb7780 0x400eacbe:0x3ffb77b0 0x400dd0f2:0x3ffb77e0 0x400e353d:0x3ffb7810 0x400e5dce:0x3ffb7830 0x400dd18c:0x3ffb78d0 0x400e353d:0x3ffb7900 0x400e3672:0x3ffb7920 0x400e5e7d:0x3ffb7940 0x400dd18c:0x3ffb79e0 0x400e353d:0x3ffb7a50 0x400e5dce:0x3ffb7a70 0x400dd18c:0x3ffb7b10 0x400e353d:0x3ffb7b40 0x400e3566:0x3ffb7b60 0x400e35ea:0x3ffb7b80 0x401040ad:0x3ffb7c10 0x401040f1:0x3ffb7c40 0x400dd101:0x3ffb7c60 0x400e353d:0x3ffb7c90 0x400e5dce:0x3ffb7cb0 0x400dd18c:0x3ffb7d50 0x400e353d:0x3ffb7d80 0x400e3566:0x3ffb7da0 0x400ecb97:0x3ffb7dc0 0x400ecf59:0x3ffb7e50 0x400ecfbd:0x3ffb7e70 0x400d71f3:0x3ffb7e90
