Questions about ntptime
liudr
Post by liudr » Wed Dec 01, 2021 5:58 am
I'm looking for ways to get time with ntptime and this is the only official reference I found:
http://docs.micropython.org/en/latest/e ... -clock-rtc
So here is how to do it:
ntptime.settime() # set the rtc datetime from the remote server
The issue is, this function calls another function time() and that function has no exception handling:
This whole thing is under ESP8266:
def time():
    NTP_QUERY = bytearray(48)
    NTP_QUERY[0] = 0x1B
    addr = socket.getaddrinfo(host, 123)[0][-1]
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
        s.settimeout(1)
        res = s.sendto(NTP_QUERY, addr)
        msg = s.recv(48)
    finally:
        s.close()
    val = struct.unpack("!I", msg[40:44])[0]
    return val - NTP_DELTA
See there is no except clause. This at times works but eventually throws errors:
File "main.py", line 1, in <module>
File "logger.py", line 130, in <module>
File "ntptime.py", line 34, in settime
File "ntptime.py", line 25, in time
OSError: [Errno 116] ETIMEDOUT
Line 25 is s.recv(48). I guess the magic number of 1 second didn't cut it. I wonder if I should just handle the exception or increase 1 second to some other magic number instead.
Also, I would like to convert this datetime tuple into timestamp. I tried a few ways but could get it right.
I know utime.mktime() should be the right tool but it seems to only create a time stamp based off 2000, not 1970.
So I came up with this:
0x100000000-a1970+time.mktime(time.localtime())
Where:
a1970=time.mktime((1970,1,1,0,0,0,0,0))
This seems to give me the correct timestamp.
So is there any more proper way to get a unix time stamp? Thanks
davef
Re: Questions about ntptime
Post by davef » Wed Dec 01, 2021 6:45 am
My solution to ETIMEOUT:
    import usocket as socket
except:
    import socket
    import ustruct as struct
except:
    import struct
import utime
# (date(2000, 1, 1) - date(1900, 1, 1)).days * 24*60*60
NTP_DELTA = 3155673600
# The NTP host can be configured at runtime by doing: ntptime.host = 'myhost.org'
host = "pool.ntp.org"
def time():
    NTP_QUERY[0] = 0x1B
    counter = 0
 #  try 5 times to get the time
        counter +=1
            s.settimeout(10) #  was 1 second
            msg = s.recv(48)
            counter = 0
            s.close()
            break
        except Exception:
                with open('errors.txt', 'a') as outfile:
                    outfile.write('getting the time failed' + '\n')
            except OSError:
                pass
        utime.sleep(5)
        if counter == 5:
            counter = 0
            utime.sleep(80) #  force a machine.reset()
# There's currently no timezone support in MicroPython, and the RTC is set in UTC time.
def settime():
    t = time()
    if t < 0:
        return False
    import utime
    tm = utime.gmtime(t)
    machine.RTC().datetime((tm[0], tm[1], tm[2], tm[6] + 1, tm[3], tm[4], tm[5], 0))
not sure it helps.
P.S. I have a software wdt running.
Post by dhylands » Wed Dec 01, 2021 7:34 pm
The difference between the Micropython 2000 epoch and the unix 1970 is a constant. You can calculate that constant in CPython by using:
import calendar
epoch_1970 = (1970, 1, 1, 0, 0, 0, 0, 0)
epoch_2000 = (2000, 1, 1, 0, 0, 0, 0, 0)
time_offset = calendar.timegm(epoch_2000) - calendar.timegm(epoch_1970)
and that will give a time_offset of 946684800 which you can code into your program, and add it to the epoch 2000 timestamp to come up with an epoch 1970 timestamp.
liudr
Post by liudr » Wed Dec 01, 2021 11:54 pm
import calendar
Thanks! I didn't know about the calendar module. It's not built-in, or in the stdlib or ecosys. Is it a 3rd-party contributed module for Python or MP?
I checked my offset with 0x100000000-a1970, exactly the same value as yours.
liudr
Post by liudr » Wed Dec 01, 2021 11:56 pm
Thanks @davef!
I'll see if I can understand your code and incorporate into my script.
Curious, are those exception handling in import supposed to make your script run on both MP and Python (or another platform)?
davef
Post by davef » Thu Dec 02, 2021 12:01 am
I only modified the existing script. The change in def settime was by Peter Hinch.
The import statements ... good question ... I think it gives the option to call some Python libraries into your Micropython script. Ones with more features.
Post by dhylands » Thu Dec 02, 2021 12:04 am
calendar comes with CPython. You can find the documentation here: https://docs.python.org/3/library/calendar.html
The documentation for the time module: https://docs.python.org/3/library/time.html#module-time has links to it as well.
liudr
Post by liudr » Thu Dec 02, 2021 12:16 am
So did you just load the calendar module in a lib/ folder on your MP board?
Post by dhylands » Thu Dec 02, 2021 1:51 am
I only use calander on the host (under CPython). And since the offset you're looking for is a constant that can't ever change you can just hard-code it into your micropython code. No need to use calendar to calculate it.
liudr
Post by liudr » Thu Dec 02, 2021 2:38 am
Right thanks. I really don't need the module, just the offset.
