ssl certificates in hex format
ttmetro
Post by ttmetro » Thu Dec 09, 2021 9:45 pm
I'm trying to get the https server example working (https://github.com/micropython/micropyt ... ver_ssl.py) and am stuck creating the certificates in the correct hex format. What I currently have:
cat << EOF >cert.conf
[req]
distinguished_name = req_distinguished_name
x509_extensions = v3_req
prompt = no
[req_distinguished_name]
C = US
ST = CA
O = MicroPython Webserver
[v3_req]
keyUsage = critical, digitalSignature, keyAgreement
extendedKeyUsage = serverAuth
subjectAltName = @alt_names
[alt_names]
DNS.1 = 10.39.40.168
IP.1  = 10.39.40.168
EOF
openssl req -x509 -nodes -days 3650 -newkey rsa:2048 \
    -keyout cert.key -out cert.crt -config cert.conf
The files
cert.key
and
cert.crt
work correctly on a host (CPython). But it look like for MicroPython I need them in hex format. How can I convert them?
Bernhard Boser
ttmetro
Re: ssl certificates in hex format
Post by ttmetro » Mon Dec 13, 2021 3:18 am
Adding
-outform PEM
to the openssl command and reading the certificates (after stripping the first and last line) in MicroPython with
with open('/ssl/cert.key') as f:
    key  = binascii.a2b_base64(f.read())
with open('/ssl/cert.crt') as f:
    cert = binascii.a2b_base64(f.read())
solves the problem.
Bernhard Boser
ttmetro
Post by ttmetro » Mon Dec 13, 2021 6:57 pm
In case anyone else runs into this issue - I've put an example at https://iot49.org/projects/internet/soc ... ure-server.
Bernhard Boser
