WDT on Lolin D32
KJM
WDT on Lolin D32
Post by KJM » Wed Jan 12, 2022 10:18 pm
How do I setup a WDT on the Lolin D32? the usual
from machine import WDT; wdt=WDT(timeout=5000)
throws an error
TypeError: function doesn't take keyword arguments
Re: WDT on Lolin D32
Post by Roberthh » Thu Jan 13, 2022 7:12 am
How about:
from machine import WDT; wdt=WDT(5000)
davef
Post by davef » Thu Jan 13, 2022 8:52 am
I was going to respond saying it works for me but after reading your comment I realised that I only use WDT on Glenn's ESP-Now ESP32 image.
If your command works then there might be something inconsistent between the two code bases.
Shards
Post by Shards » Thu Jan 13, 2022 4:11 pm
The standard wdt = WDT(timeout=5000) works fine for me and Robert's suggested version fails. I'm not testing with a Lolin board but it is an ESP32-WROOM-32 module from AZ-Delivery running the latest stable 1.17 which should be same spec as the Lolin. Is your build up-to-date?
KJM
Post by KJM » Thu Jan 13, 2022 8:30 pm
Robert's suggestion gives a value error. The D32 arrived with micropython already installed, (sysname='esp32', nodename='esp32', release='1.10.0', version='v1.10-195-gfcace26d8 on 2019-03-12', machine='ESP32 module with ESP32'). I guess March 2019 is a bit old but I haven't yet mastered the art of flashing my own.
Post by Roberthh » Thu Jan 13, 2022 8:36 pm
That's right. On recent firmware, it has to be either WDT(timeout=5000) or WDT(0, 5000). For compatibility with other ports (I guess), there is an id parameter, which has to be 0.
KJM
Post by KJM » Sat Jan 15, 2022 12:56 pm
The pin HOLD doesn't work either, guess I better have a crack at flashing a more recent micropython.
KJM
Post by KJM » Sun Jan 16, 2022 12:03 am
I flashed the latest upython onto a Lolin D32 after I started to get OSError 28 trying to flash main.py but I'm worried it will be only a matter of time before the file system falls over again. Is there a way to tell if release='1.17.0' uses FAT or littleFS? Is there a stable upython out there that uses littleFS by default?
