I am trying to build ESP32 GENERIC_SPIRAM board with st7789_mpy native driver.
I build using the v1.18 branch, did it with esp-idf 4.2, 4.2.2 and 4.3.2.
Here is the command I use to build.
make USER_C_MODULES=~/st7789_mpy/st7789/micropython.cmake BOARD=GENERIC_SPIRAM -j 2
Here is the error I am getting with 4.2 and 4.2.2.
Project build complete. To flash, run this command:
/home/erong/.espressif/python_env/idf4.2_py3.7_env/bin/python ../../../esp-idf-4.2/components/esptool_py/esptool/esptool.py -p (PORT) -b 460800 --before default_reset --after hard_reset --chip esp32 write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x1000 build-GENERIC_SPIRAM/bootloader/bootloader.bin 0x8000 build-GENERIC_SPIRAM/partition_table/partition-table.bin 0x10000 build-GENERIC_SPIRAM/micropython.bin
or run 'idf.py -p (PORT) flash'
bootloader @0x001000 21600 ( 7072 remaining)
partitions @0x008000 3072 ( 1024 remaining)
application @0x010000 1584560 ( -11696 remaining)
ERROR: application overflows allocated space of 1572864 bytes by 11696 bytes
make: *** [Makefile:35: all] Error 1
Here is the error I am getting with 4.3.2.
/home/erong/.espressif/tools/xtensa-esp32-elf/esp-2021r2-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: micropython.elf section .iram0.text' will not fit in region iram0_0_seg'
/home/erong/.espressif/tools/xtensa-esp32-elf/esp-2021r2-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: IRAM0 segment data does not fit.
/home/erong/.espressif/tools/xtensa-esp32-elf/esp-2021r2-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: region `iram0_0_seg' overflowed by 392 bytes
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
make: *** [Makefile:34: all] Error 2
The same works fine with build for ESP32 GENERIC and ESP32S2 board. And it was working fine with v1.17 branch. Would appreciate any help.
