how to make urequests asynchronous?
kenjican
Re: how to make urequests asynchronous?
Post by kenjican » Sun Jan 30, 2022 5:35 am
@curt
Thanks for advises. But TCP and SSL is a must.
@marcidy
await sWriter.drain() works. But I found that asyncio.open_connection doesn't support "ssl=True" parameter
I try to make ssl sokcet:
sWriter = ussl.wrap_socket(sWriter.s,server_hostname=ip)
It shows : OSError: (-29312, 'MBEDTLS_ERR_SSL_CONN_EOF')
Any idea?
marcidy
Post by marcidy » Sun Jan 30, 2022 6:21 am
try creating the socket like in examples/network/http_client.py:
    import usocket as _socket
except:
    import _socket
    import ussl as ssl
except:
    import ssl
def main(use_stream=True):
    s = _socket.socket()
    ai = _socket.getaddrinfo("google.com", 443)
    print("Address infos:", ai)
    addr = ai[0][-1]
    print("Connect address:", addr)
    s.connect(addr)
    s = ssl.wrap_socket(s)
    print(s)
    if use_stream:
        # Both CPython and MicroPython SSLSocket objects support read() and
        # write() methods.
        s.write(b"GET / HTTP/1.0\r\n\r\n")
        print(s.read(4096))
        # MicroPython SSLSocket objects implement only stream interface, not
        # socket interface
        s.send(b"GET / HTTP/1.0\r\n\r\n")
        print(s.recv(4096))
    s.close()
Then create the stream with the created socket. let me know if it works, I haven't gone this far :D
kenjican
Post by kenjican » Tue Feb 01, 2022 1:10 am
Thanks for great advices. I modified urequests with uasyncio.stream . It seems working.
I put the code in urequests_ff
Post by pythoncoder » Tue Feb 01, 2022 10:45 am
Congratulations on getting this working. Why have you created your own copy of uasyncio.Stream? As far as I can see the code is identical to the official built-in version.
kenjican
Post by kenjican » Tue Feb 01, 2022 2:11 pm
em.. To modify urequests.py would be easier,just because aysncio is build-in. I have no idea how to modify build-in modules.
If asyncio module has requests function, it would be great. I think people need it.
kenjican
Post by kenjican » Wed Feb 02, 2022 3:18 pm
Sorry, I might misunderstood your question.
The code I modified are from these two places:
1: urequests: https://github.com/micropython/micropyt ... /urequests
2: asyncio : https://github.com/micropython/micropyt ... d/uasyncio
Post by pythoncoder » Wed Feb 02, 2022 7:28 pm
I understand why you modified urequests. I'm puzzled why you copied uasyncio code to your own module unchanged, when that code is already built in to firmware. You'd save space by simply using the built-in Stream:
from uasyncio import core, Stream
kenjican
Post by kenjican » Fri Feb 04, 2022 3:50 am
Thanks for the advice. Yes, to import is a resource-saving solution.Much better than copy :D
Post by pythoncoder » Fri Feb 04, 2022 9:33 am
It also means that you get the benefit of any bugfixes implemented by the maintainers.
