ESP32 analogRead attenuation and accuracy
liudr
Post by liudr » Mon Feb 21, 2022 4:00 am
I read from here that there are several attenuation levels of the ADC:
https://docs.micropython.org/en/latest/ ... conversion
On the other hand, random nerd tutorials has a different set of ranges with the same attenuation levels:
https://randomnerdtutorials.com/esp32-e ... cropython/
ESP32 MP doc:
ADC.ATTN_11DB: 11dB attenuation (150mV - 2450mV)
Random nerd:
ADC.ATTN_11DB — the full range voltage: 3.3V
My tests show that Random nerd is possibly correct. The results are a bit off. My supply measures 3.29V so I'm only 0.3% less than 3.3V. But my readout is 0.16V less than my Fluke meter. This isn't from the 2.45V vs 3.3V I think.
So I read further on ESP32 MP doc:
ADC.read_uv()¶
This method uses the known characteristics of the ADC and per-package eFuse values - set during manufacture - to return a calibrated input voltage (before attenuation) in microvolts. The returned value has only millivolt resolution (i.e., will always be a multiple of 1000 microvolts).
The calibration is only valid across the linear range of the ADC. In particular, an input tied to ground will read as a value above 0 microvolts. Within the linear range, however, more accurate and consistent results will be obtained than using read_u16() and scaling the result with a constant.
So this ADC.read_uv(), it doesn't exist in 1.17 firmware. I tried 1.18. It's not there either. i wonder if this is just an issue with the document maybe copy-pasted from pyboard. The call class ADC(pin, *, atten) also doesn't work. It only takes 1 parameter. So under the current scenario, is there any way to read voltages more accurately? Thanks.
Here is another reference from sparkfun saying a 0.2V discrepancy. My issue isn't the 0.2V. I have a voltage divider with 510K/100K to read 12V battery voltages. That scaling makes 0.2V scale to over 1V of difference. I wish I could make more accurate reading using factory calibration.
KJM
Re: ESP32 analogRead attenuation and accuracy
Post by KJM » Mon Feb 21, 2022 7:41 am
I've wound up the voltage at the analog inputs of several ESP32s set to ATTN_11DB over the years. I found the max 4095 count is reached at around 3.13v on my Fluke87.
liudr
Post by liudr » Mon Feb 21, 2022 8:19 pm
So maybe the high and low ends of the voltage range doesn't go linear enough. What about the mid section like say 2V? Is 2V represented by 2/3.3*4096?
Thanks.
KJM
Post by KJM » Mon Feb 21, 2022 10:59 pm
Check the graph about half way down the page https://randomnerdtutorials.com/esp32-p ... nce-gpios/
scruss
Post by scruss » Tue Feb 22, 2022 4:59 am
It came out after 1.18, so is in the nightlies:
from machine import ADC, Pin
import os
print(os.uname())
a=ADC(Pin(33))
a.atten(ADC.ATTN_11DB)
print(a.read_uv()/1e6)
which gives:
(sysname='esp32', nodename='esp32', release='1.18.0', version='v1.18 on 2022-02-22', machine='ESP32 module with ESP32')
0.142
liudr
Post by liudr » Fri Mar 04, 2022 10:33 pm
import os
print(os.uname())
a=ADC(Pin(33))
which gives:
0.142
Thanks and sorry for the delay. So is this method more accurate than the legacy method? I'll give it a test on a dev board myself when I get some time.
Online
davef
Post by davef » Fri Mar 04, 2022 10:37 pm
Pivert
Post by Pivert » Sun Aug 28, 2022 10:02 am
Also check this excellent article about accuracy of the ESP32 ADC
https://w4krl.com/esp32-analog-to-digit ... -accuracy/
