I didn't find any reference on the official doc. I did find this post that uses wiznet chipset over SPI without any reference of the working solution:
viewtopic.php?f=18&t=11378&p=62493&hili ... net#p62493
I was hoping for the native Ethernet on ESP32 but any external hardware support is good as well since I wish to use PSRAM and EMAC pins may interfere with PSRAM's chip select pins.
I looked up the lobo's firmware that does have support of ESP32's native ethernet with a LAN8720 physical module but lobo's firmware is probably not up to date anymore.
I'm hoping to be able to drive an ethernet module over SPI pins. That will be easy to add on.
Does micropython ESP32 support Ethernet?
Re: Does micropython ESP32 support Ethernet?
Hi, did you find any solution?liudr wrote: ↑Fri Apr 08, 2022 4:31 amI didn't find any reference on the official doc. I did find this post that uses wiznet chipset over SPI without any reference of the working solution:
I would like a SPI ethernet W5500 (Wiznet5500) driver for the ESP32 too, but nothing until now
I see that ESP-IDF recently released support for the Wiznet5500: https://github.com/espressif/esp-idf/tr ... basic/main
I created a issue (https://github.com/micropython/micropython/issues/8537) in the MicroPython github ansking a feature request based on that driver.
Thanks! I replied to your git issue. I think it's best to have a native mp version of the driver instead of using some wrappers over IDF functions. This way there will be a wider support over all mp board types instead of just for ESP32.
