WiFi re-connect problem
davef
Post by davef » Thu Apr 21, 2022 3:55 am
Have been trying to get an application to continue running even when the WiFi
fails to connect. v1.18 Generic.
Error message is:
OSError: WiFi internal error (something like this as I can't repeat it)
If I run the following connect() and the WiFi does not connect I make
sta_if.active(False), but this still seems to leave the WiFi in limbo ... sometimes.
Only a hard-reset allows me to run the application again.
import utime
import config
sta_if = network.WLAN(network.STA_IF) # create station interface
ap_if = network.WLAN(network.AP_IF) #  create access-point interface
def connect():
    count = 0
 #  disconnects AP if it is up
    ap_if.active(False) #  de-activate the AP interface
    utime.sleep(1)
    if not sta_if.isconnected():
        print('connecting to hotspot...')
        sta_if.active(True)
        sta_if.ifconfig((config.WiFi_device, '255.255.255.0', config.gateway, '8.8.8.8'))
        sta_if.connect(config.hotspot, config.password)
        while (count < 5):
            count += 1
            if (sta_if.isconnected()):
                count = 0
                print (' network config:', sta_if.ifconfig())
                break
            print ('.', end = '')
            utime.sleep(1)
    if (count == 5):
     #  disconnect or you get errors
        if (sta_if.isconnected()): #  maybe not necessary
            sta_if.disconnect()
        sta_if.active(False) #  this is necessary
    count = 0 #  reset count
    utime.sleep(1)
Is there something else I can do to make sure that the WiFi is ready to try and reconnect
say one minute later?
tepalia02
Re: WiFi re-connect problem
Post by tepalia02 » Thu Apr 21, 2022 9:44 am
I can see
mport network
Have you missed the 'i' when typing?
davef
Post by davef » Thu Apr 21, 2022 10:24 am
Copy/paste problem :)
My only half-baked theory is that machine.reset() does not do as good a job as a hard-reset, ie the EN button, for getting the WiFi to its initial or default state.
Shards
Post by Shards » Thu Apr 21, 2022 11:09 am
If you want the program to continue to run you need to trap the 'Wifi Internal Error' with a try: except: block. you can then ignore the error and try connecting again. Certainly not best practice but I fairly consistently get the error, sometimes multiple times, and the code below gets it connected. Once connected it seems reasonably stable. This is my basic test code:
from net_config import SSID, PSWD
from time import sleep
net = network.WLAN(network.STA_IF)
net.active(True)
		net.connect(SSID,PSWD)
	except OSError as e:
		print(e)
	sleep(1)
	if net.isconnected():
		print('Connected')
		break
marcidy
Post by marcidy » Thu Apr 21, 2022 4:56 pm
I would explicitly call disconnect() before calling active(False). disconnect() resets some internal micropython state, and stops the interface from making connection attempts.
what you have will never run if the station never connects:
            sta_if.disconnect()
so just get rid of the "if" statement. "isconnected()" doesn't cover "trying to connect but not yet connected".
davef
Post by davef » Thu Apr 21, 2022 8:04 pm
Thank you. I will modify it as you suggest. My real connect() method has some error logging in it so I will be able to see if it improves the situation.
davef
Post by davef » Sun Apr 24, 2022 8:53 pm
Think I finally nailed this problem.
Running this test.py:
from wifi_functions import connect
from wifi_functions import disconnect
import utime
    connect()
    utime.sleep(5)
    disconnect()
    print ('disconnected')
    utime.sleep(5)
and my wifi_functions.py
import utime
import config
def connect():
    count = 0
    utime.sleep(1)
        sta_if.active(True)
        while (count < 5):
            count += 1
                count = 0
                break
            utime.sleep(1)
    if (count == 5):
            with open('errors.txt', 'a') as outfile:
                outfile.write('failed to connect' + '\n')
        except OSError:
            pass
        disconnect()
    utime.sleep(1)
def disconnect():
 #  disconnects STA, even if it is not connected
    sta_if.disconnect()  #  This is line 59
    utime.sleep(1)
I would get this error:
MPY: soft reboot
.....Traceback (most recent call last):
  File "main.py", line 2, in <module>
  File "test.py", line 12, in <module>
  File "wifi_functions.py", line 59, in disconnect
OSError: Wifi Not Started
MicroPython v1.18 on 2022-01-17; ESP32 module with ESP32
I guess it is not a surprise that trying to disconnect when you are NOT connected
might be an issue. Re-reading Shards response I thought I would put line 59
in a try ... except block.
def disconnect():
        sta_if.disconnect()
    except:
        pass
    utime.sleep(1)
Voila!! No more ... OSError: Wifi Not Started
When running test.py if you do a Ctrl C during the connection attempt, then another
CtrlD I get:
MPY: soft reboot
E (63083) wifi:sta is connecting, return error
  File "test.py", line 10, in <module>
  File "wifi_functions.py", line 24, in connect
OSError: Wifi Internal Error
Type "help()" for more information
This suggests that:
should be a try ... except block. But that was what Shards recommended in the first place!!
I hope this is another step towards getting reliable WiFi access.
Thanks to both of you for your suggestions.
