I've searched around the internet and couldn't find a micropython module that supports W5500 Ethernet adapter. I think it's a necessary component of MP's ecosystem since most MP-compatible boards don't have WiFi like ESP32 does and Ethernet also provides stable networking. The circuitpython module that "works" with W5500 doesn't actually work even under circuitpython. I got it to receive IP address with DHCP but couldn't do any requests as the requests module was not found.
So is there any effort to write an MP driver so all MP boards could benefit from having this? Thanks!
ESP32 micropython support of W5500 Ethernet
Re: ESP32 micropython support of W5500 Ethernet
I found this reference:
https://docs.micropython.org/en/v1.17/l ... NET5K.html
But when I tried it on my MP 1.17 ESP32, there is no network.WIZNET5K. Here is a blurb:
Has anyone done it to confirm that compiling my own mp firmware will let me use W5500?
I've used IDF extensively but it's been some time since I last did a project on it. It would be great to see some tutorial how to compile mp firmware. I also want to expand the file system to 8MB or even 16MB with WROVER-E modules that have 16MB FLASH. I guess I can only do that if I compile my own mp firmware, correct?
Does this mean I have to attempt to compile my own mp firmware if I want to use this feature?The particular chipset that is supported by the firmware is selected at compile-time via the MICROPY_PY_WIZNET5K option.
Wiznet support is being worked on for the RP2040 now (https://github.com/micropython/micropython/pull/8540).
When that is working it will probably be possible to get it working with ESP32 aswell.
That's Great! I noticed your forum handle. Are you anyway related to the lobos firmware that was out around 2018-19?
No, different Lobo.
Not sure the progress. The git pull comments are too technical for me. Any update?
The RP2040 version is in the Master branch now. And the Wiznet driver should now be relatively easy to get to work on other ports.
https://github.com/micropython/micropyt ... 1147986269
https://github.com/micropython/micropyt ... 1151701493
But someone has to actually do it...
Thanks. I am just a developer, not very well-versed in git. I have no idea how to do this. I have cloned micropython and micropython-libs and just pulled from master. I can also build python. I did that a few times so I can refer to my notes and experience using IDF. Then if you could point out to me how I can include the Wiznet driver in my build and run a simple example, that would be great!
I know that last time I did the build, the build didn't include a wiznet driver. I did help("modules") on it.
