I2S missing
dave1167
I2S missing
Post by dave1167 » Fri May 06, 2022 1:04 pm
Hi All
Quite new to ESP32 so still on a steep learning curve
I'm having trouble finding the I2S library in Micropython V1.18 on an ESP32-C3 board. This is the start of the code
import os
import math
import struct
from machine import I2S
and the error I get is
File "<stdin>", line 18, in <module>
ImportError: can't import name I2S
Is I2S a sub module of machine? or has it moved elesewhere?
Can anyone see an obvious reason why it fails?
Thanks in advance
Mike Teachman
Re: I2S missing
Post by Mike Teachman » Fri May 06, 2022 7:54 pm
The I2S class is presently excluded for all C3 boards.
in ports/esp32/boards/GENERIC_C3/mpconfigboard.h:
#define MICROPY_PY_MACHINE_I2S              (0)
I don't know the background on this exclusion. I suggest to raise an Issue at https://github.com/micropython/micropython/issues
dave1167
Re: I2S missing
Post by dave1167 » Fri May 06, 2022 11:22 pm
Thanks Mike, I will do
andypiper
Re: I2S missing
Post by andypiper » Sun May 08, 2022 10:33 pm
Some code archaeology indicates that the initial ESP32-C3 support went into MicroPython on 18th July 2021, but the support for I2S on ESP32-C3 didn't get into ESP-IDF itself until several weeks later, in August. So, at a guess, it was excluded from the original generic config, and has not been added in since then.
I have an array of C3 boards to play with here, but no I2S devices, so I could fairly quickly roll a build from HEAD that included I2S support, but I wouldn't be able to test that it was functional.
