Connection to THINGSPEAK , IOT, ESP32 ,Cloud,DHT11
Posted: Thu Jun 02, 2022 7:11 pm
by ixbo
Hello.....
It try to store data (temperature and humidity) from a sensor DHT11 to a cloud service (ThingSpeak)
(https://thingspeak.com/)in witch I've create my account (free) create my fields....I have my write API KEY and so on......
My program do not work , I try an other one (below) from"ELEKTOR" joined with my MAKEPYTHON ESP32 DEVELOPMENT KIT
#              	TEMPERATURE AND HUMIDITY ON THE CLOUD
# The temperature and humidity sensor DHT11 is connected to IO14
# of the development board. The project reads the temperature
# and humidity and sends to the cloud where it can be accessed
# from anywhere. In addition, change of the temperature and the
# humidity can be plotted in the cloud.
# The program uses the Thingspeak cloud service.MakePython ESP32
# must be connected to Wi-Fi router before data is sent to the cloud
# Author: Dogan Ibrahim
# File  : Cloud.py
# Date  : January, 2021
import socket
import dht
APIKEY = "DHLZXHLPALHV12Q3"                # my API Write Key !!!!!!
# This function connects to the Wi-Fi
def Connect_WiFi():
    net = network.WLAN(network.STA_IF)
    if not net.isconnected():
       net.active(True)
       net.connect(“My_SSID”, “My_PassWord”)
       print(net.ifconfig())
# This function returns the temperature and humidity
def TempHun():
    d = dht.DHT11(Pin(14))                  # DHT11 at IO14
    d.measure()
    t = d.temperature()
    h = d.humidity()
    return t, h
# Send data to Thingspeak. This function sends the temperature and
# humidity data to the cloud every 30 seconds
    Connect_WiFi()
    sock = socket.socket()
[color=#FF0000][b]    addr = socket.getaddrinfo("api.thingspeak.com",80)[0][-1][/b][/color]
    sock.connect(addr)
    (t, h) = TempHun()
    host = "api.thingspeak.com"
    path = "api_key="+APIKEY+"&field1="+str(t)+"&field2="+str(h)
    sock.send(bytes("GET /update?%s HTTP/1.0\r\nHost: %s\r\n\r\n" %(path,host),"utf8"))
    sock.close()
    time.sleep(30)
well connected to my box, DHT11 work well.....but no more
the instruction seems to be wrong:
line 54 ===> addr = socket.getaddrinfo("api.thingspeak.com",80)[0][-1]
ERROR
File "<stdin>", line54, in <module>
OSError: -202
I have not found what is wrong !!!!
can you help me to understand this problem
Thanks very much
Best regards
Re: Connection to THINGSPEAK , IOT, ESP32 ,Cloud,DHT11
Posted: Thu Jun 02, 2022 7:23 pm
by davef
I tried Google:
OSError: 202
and got lots of hits BUT
OSError: -202
did not. Weird!
The - sign is specific to Micopython. I looked at a few of the Micropython specific hits, do any of those provide any clues?
Good luck.
Posted: Thu Jun 02, 2022 10:28 pm
by ixbo
Thank you for the answer
Since several days I try to find a solution....
I try a sample given by Micropython.org they don't work
I'm connected to WiFi
But....................
import socket
print(addr)
IP MASQ GATEWAY DNS
('192.168.1.33', '255.255.255.0', '192.168.1.254', '32.1.8.97')
File "<stdin>", line 61, in <module>
OSError: -202
Now I replace "api.thingspeak.com" by "3.223.163.200"
witch is IP address now it's good
import socket
addr = socket.getaddrinfo("3.223.163.200",80)
print(addr)
IP MASQ GATEWAY DNS
('192.168.1.33',
[(2, 1, 0, '3.223.163.200', ('3.223.163.200', 80))]
thanks very much !!!!
Best regards
